Forums Migration
Please read this thread
High Flow Thermostats
by Nick1994 - 07/12/20 02:51 AM
Hy-per Lube ZDDP Supplement 6pk $13.00
by alchargo - 07/11/20 10:38 PM
97 Civic HX valve cover pics
by CARJ - 07/11/20 10:22 PM
Time to ditch Speedplays
by UG_Passat - 07/11/20 10:03 PM
Dale L Nuzum
by Dalenuzum - 07/11/20 10:02 PM
*BANG* (Garage Door Spring)
by ctechbob - 07/11/20 09:40 PM
TPMS Sensors
by 92saturnsl2 - 07/11/20 09:16 PM
Chevron Delo 400 XSP 5W-30 XSP
by Gene K - 07/11/20 08:48 PM
LED retrofit for recessed can lights
by Donald - 07/11/20 07:08 PM
PP HM 5W-20 $15 at Wally
by Jackson_Slugger - 07/11/20 07:03 PM
Defeated by roll pin
by bcossa2001 - 07/11/20 06:56 PM
Dexron VI in place of Mercon LV?
by BigLee - 07/11/20 06:50 PM
89 c4 oil
by dogememe - 07/11/20 06:17 PM
Noticed the Titanium info.
by Farnsworth - 07/11/20 06:16 PM
FebiBilstein Parts
by willbur - 07/11/20 06:03 PM
Life goes on
by 53' Stude - 07/11/20 06:02 PM
Lubegard in a GM transfer case?
by BlakeB - 07/11/20 05:21 PM
Is MSO2 Liquid Moly OK in DIG NA engines
by JimPghPA - 07/11/20 03:10 PM
Rider Magazine Question
by Smoky14 - 07/11/20 02:38 PM
cadillactech, ILoveOil111, quantalume, SUmeme22, DaveCaddell
71910 Registered Users
31 registered members (Char Baby, Ausfahrt, d00df00d, blufeb95, CPA1989, 5 invisible), 570 guests, and 47 spiders.
Topics307,747
Posts5,316,942
Members71,910
Reman CV axle = good, new aftermarket = bad #4407646 05/18/17 07:38 AM
K
Klutch9 Offline OP
K
This is more of a rant than anything else, regarding the quality of two new aftermarket CV joints I received, vs a remanned OEM unit.
Less than two years ago I had the driver's side CV axle replaced on my van; had a bad inner joint. Having never done an axle before, and because I cannot live without my van for work for more than a day or so, I decided to have it done by a shop. They gave a free loaner car, were local, nice people, growing business, etc. They got the new axle put in quickly, and immediately I noticed a vibration on acceleration. This points to a bad inner joint on the axle. I took it back, and thankfully they replicated it and replaced it, stating that the outer joint had play. At any rate, this second axle was improved, but the vibration was still there. I tried replicating it for them, but could never. They offered to balance wheels/tires even though this clearly wasn't the issue. I decided to live with it for awhile until recently, when the vibration became worse. I drive a lot so I was sick of it!
I decided to have a go at replacing it myself, and bought a remanned OEM unit from Napa, which is from A-1 Cardone. I say OEM reman, since it looks identical to the OEM axle on the passenger side. At any rate, the install went well and the vibrations are gone; feels like a new car! But the shocking thing was just how cheap the 'new' aftermarket axle was that came out. The remanned axle had a noticeably thicker axle shaft, a beefier CV/outer joint, and the inner tripod joint was so much more substantial, it looked like the wrong part at first. Both joints did have play on the old axle. Additionally, the aftermarket shaft also had a 1 mm smaller hex on the axle nut... odd. Thankfully I had just purchased an axle nut kit with several sockets. I know I'm out the money I spent the first time around, but I may bring the old axle by the shop to show them what their 'new' parts are doing in customer vehicles. Lesson learned.
'11 Fusion SE 2.5L - 93k miles - HK 0w20 syn, Carquest Blue filter
'08 Sedona LX LWB 3.8L - 149k miles - Havoline HM 5w20, Fram XG filter
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4407656 05/18/17 07:56 AM
Chris142 Offline
The remanned axle wont last. When they grind the ball grooves for bigger balls they remove the hardning.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4407662 05/18/17 08:04 AM
J
jeepman3071 Offline
J
I buy OEM parts whenever possible. It is almost always worth the extra money.
My friend owns a 2007 Chevy Silverado with around 120k. The driver side front wheel bearing has been replaced three times now with the cheap "Duralast" junk and he keeps bringing them back because of the lifetime warranty. What a rip off. I don't care if they give me a free one, I hate taking stuff apart more than once. The passenger side wheel bearing is original. His alignment is fine and all bolts were torqued to spec.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (63k) - Liqui Moly 5w40, MANN HU816X
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4407669 05/18/17 08:13 AM
R
robertcope Offline
R
I replaced the axles on my S2000 with "parts store remanufactured" units because it was either that $100 part of a $1000 part. I'm going to have to buy the $1000 part, after all; the cheap part just didn't hold up for more than a few months. Granted, that included a few track days, but still not very impressive.
Re: Reman CV axle = good, new aftermarket = bad [Re: Chris142] #4407690 05/18/17 08:38 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
+1.
Some outfits only use better used parts as the basis for cores and dont do this. The rebuilder in Colorado (forget the name) is a good one, but of course they will cost more than the $29 parts store specials...
Pure speculation, but I wonder if the "new aftermarket" units are victims of part number consolidation, so one part is used for a variety of applications/vendors, without doing a true, rigorous check out...
Re: Reman CV axle = good, new aftermarket = bad [Re: JHZR2] #4407702 05/18/17 08:46 AM
K
Klutch9 Offline OP
K
+1.
I think your speculation is correct. My remanned axle was more than $29, so let's hope it lasts awhile! As to the poster who mentioned the hardening being ground away... what type of hardening do they use originally? If it's a coating of some sort, then that makes sense. But if it's heat-treated, grinding won't remove the hardening characteristics.
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4407723 05/18/17 09:17 AM
O
Oldmoparguy1 Offline
O
I always buy new CV axles. I've never had a reman last, sometimes they are bad out of the box.
YMMV
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Reman CV axle = good, new aftermarket = bad [Re: Chris142] #4407889 05/18/17 01:02 PM
K
Kool1 Offline
K
I agree that aftermarket remanufactured axles won't last as they grind the grooves, but do they do this with factory OEM remanufactured axles or do they put in new CV joints at the axle ends?
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4407893 05/18/17 01:08 PM
O
Olas Offline
O
Are CV joint kits so expensive that you have to buy a used driveshaft with used CVs attached?
In Europe we keep the shaft and just put a new joint on, quicker and cheaper and no unknown variables not the equation.
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4407898 05/18/17 01:15 PM
A
andyd Offline
A
Changing the torn boot on an axle was my first job on my 528e. A messy job. But other than that, no big deal. I had step by step instructions in the Bentley manual. Mostly clean, re-grease, slide the boot down. Do FWD CV joints wear? Because the joint balls and groves were perfectly smooth.
Thick oil is better grin2
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4407948 05/18/17 02:09 PM
N
NormanBuntz Offline
N
I also decided to use a NAPA Max Drive CV axle made by Cardone Industries for my Honda. Cost of the part was $91. Because of low volume sales, Honda did not offer a factory remanufactured axle but they had a new one for $270.
So far so good. No vibrations at all. Hope I never have to use the "lifetime warranty."
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 13K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Reman CV axle = good, new aftermarket = bad [Re: NormanBuntz] #4407980 05/18/17 02:38 PM
K
Kira Offline
K
After reading this thread I am going to get a feel for axle prices at RockAuto.com THEN go to my local Volvo dealer to see what the prices are like for "newbies".
Re: Reman CV axle = good, new aftermarket = bad [Re: Olas] #4407984 05/18/17 02:43 PM
Cardenio327 Offline
We just change the joint and keep the original shaft in Mexico too.
Re-manufactured shaft assemblies became super popular in the USA because of low cost and less labor hours compared to just changing the joint. If you try to change the joint on a shaft assembly that has been re-manufactured or replaced with a new aftermarket shaft assembly, the spline count and shaft size will probably be different than OEM, so good luck finding a joint that fits.
'08 Honda C90ST Super Cub 15w-40 mixture of Delvac & Rotella
'08 Honda NX4 Falcon 5w-40 Delo 400LE
'09 Honda Fit LX 0w-20 PP
Re: Reman CV axle = good, new aftermarket = bad [Re: andyd] #4407989 05/18/17 02:46 PM
Cardenio327 Offline
fwd outer joints do wear more than rwd. Also, if they have been run for any amount of time with a torn boot and sand, mud, or water has gotten in, they're ruined.
Re: Reman CV axle = good, new aftermarket = bad [Re: Klutch9] #4408059 05/18/17 04:29 PM
N
nthach Offline
N
I had nothing but trouble with reman and most Chinese axles. I prefer to reboot OEM if possible.
