I'm planning on changing differential fluid on an Infiniti G35.
I have four jack stands but I'm wondering if it's absolutely necessary to use four jack stands. The rear diff cover has the drain bolt on its face but the fill bolt on the side.
Does it matter if the car is slightly sloped when filling the diff? Does that extra little or extra less warrant putting it on all four?
