When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
112 registered members (Anduril, 2015_PSD, 2009Edge, 2whlgeezer, andyd, 13 invisible), 2,077 guests, and 60 spiders.
Topics286,160
Posts4,903,325
Members67,569
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
CK-4 RT6: What have they done? #4403418
05/12/17 10:10 PM
05/12/17 10:10 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
I'll tell you what they've done. They've taken an oil I've run successfully for years, and turned it into some kind of a wimpy near-beer.
From Polaris Laboratories:
KV100: 14.6 cSt
TAN: 2.68
Silicon: 5 ppm
Sodium: 3
Potassium: 2
Titanium: 1
Boron: 186
Magnesium: 80
Calcium: 1978
Phosphorous: 944
Zinc: 1109
These are all the metals that were present. Where is Moly?
The zddp content has really dropped off.
Magnesium is almost gone, compared to the previous formulation.
This doesn't look like a long life oil anymore.
I think I need to start considering alternatives.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403425
05/12/17 10:21 PM
05/12/17 10:21 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
It's not surprising right? Environmentally friendly has somehow beat superior protection, and we have to live with the results of this policy.
Is the batch you test dual rated for gas engines and SN? Or still SM?
And is there a way you can change the title so it says "Roellta T6" instead of RT6? (for future search purposes -- we don't all know the same acronyms)
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403427
05/12/17 10:22 PM
05/12/17 10:22 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I don't think rotella ever moly. Delo has moly. The boron makes up for the lack of zddp.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403428
05/12/17 10:24 PM
05/12/17 10:24 PM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Before anyone else parrots the nonsense...
"There are things that don't show up in an oil analysis."
I agree with A_Harman. CK-4's look weak, and whether or not things show in an analysis or not, what we have judged by for a long time is long gone.
I must have missed the "Save the DPF's" flyers somewhere....
beanoil: Tough under heat, real dirty afterwards.
Re: CK-4 RT6: What have they done? [Re: beanoil] #4403430
05/12/17 10:26 PM
05/12/17 10:26 PM
Houston, Texas
Houston, Texas
So can you just spike the oil with a good zddp additive? Or is that not the same?
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403431
05/12/17 10:27 PM
05/12/17 10:27 PM
Houston, Texas
Houston, Texas
That's what i'll start doing I guess.
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403433
05/12/17 10:29 PM
05/12/17 10:29 PM
MD
claluja Offline
claluja  Offline
MD
Yep weak. Still p!sses me off how they snuck this new CK4 in their CJ4 bottles for months knowing that Ford was telling their diesel customers not to use the CK4. I was a loyal RT6 guy - never again.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
2018 Jeep Rubicon, Pentastar 3.6L
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403440
05/12/17 10:39 PM
05/12/17 10:39 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
OP, where is your objective evidence to substantiate your claims that it is not a long life oil, or that it won't protect as well? If it is meant to be environmentally friendly, if anything, it will be a longer life oil. I don't see any current specs being less stringent than older ones...
I get it if you have some older vehicles, the zddp and flat tappet cam issue may be a concern...
Re: CK-4 RT6: What have they done? [Re: JHZR2] #4403449
05/12/17 10:47 PM
05/12/17 10:47 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
Cummins B-series engine has a flat-tappet cam.
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403477
05/13/17 01:18 AM
05/13/17 01:18 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
redline does all the protecting any engine will ever need.
Cable ties should hold it
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403483
05/13/17 02:20 AM
05/13/17 02:20 AM
Houston, TX
czbrian Offline
czbrian  Offline
Houston, TX
I dont understand why you are complaining. In the UOA you posted your wear metals are lower than previous samples. Other than a slightly lower TBN, the oil is working just fine.
Re: CK-4 RT6: What have they done? [Re: A_Harman] #4403524
05/13/17 05:51 AM
05/13/17 05:51 AM
quebec canada
yvon_la Offline
yvon_la  Offline
quebec canada
Plating an engine only work if wire touch (main ground isn't enough to achieve this. Yes oil maker had to reformulate. We all see how oil do from now on with all electrical wire air gaped
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Re: CK-4 RT6: What have they done? [Re: czbrian] #4403525
05/13/17 05:52 AM
05/13/17 05:52 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Didn't we all agree never to mention UOA metals as valid indicators of wear ever again?...I could have sworn....
Re: CK-4 RT6: What have they done? [Re: yvon_la] #4403539
05/13/17 06:25 AM
05/13/17 06:25 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Re: CK-4 RT6: What have they done? [Re: czbrian] #4403545
05/13/17 06:43 AM
05/13/17 06:43 AM
MD
claluja Offline
claluja  Offline
MD
Note the difference in P and Zn, between the UOA and this VOA.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
Page 1 of 3 1 2 3
