Originally Posted By: jim302
... It is probably OK for 5,000 miles but I still prefer a more traditional bypass setup just for the piece of mind.
Agreed, and same here. The popular Super Tech9688 and ST3614 both use separate dome bypass. WM's around here seem to have some difficulty keeping those two in stock. For $2.85 and based on anecdotes posted, easily worth that imo.
As for efficiency of the ST (and MicroGard), based on available data points as noted still better than some OEM with engine reliability that is generally well respected.
And then there's the oft praised made in China jobber filter anecdotes posted here. They generally do look excellent post use too, but have no published or known efficiency at all. Seems logical to me, if you like them you would generally also like the NPS, ST and MG.
Thanks for c&p.
