PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
107 registered members (69GTX, arowbat, 69Torino, 2018matto, 2012AccentSE, 16 invisible), 1,935 guests, and 57 spiders.
Topics286,181
Posts4,903,706
Members67,574
Most Online2,967
Mar 10th, 2019
Oil causing problems in VVT engines #4400467
05/09/17 06:59 PM
05/09/17 06:59 PM
Warner Robins, GA
nwjones18 Offline OP
Warner Robins, GA
Recently my STS V8 began throwing several camshaft position sensor codes and having clattering/rattling noises that would appear under acceleration then go away at idle (I assume noise was when the VVT was trying to kick in I don't claim to fully understand how it works). I could not find a problem, but the noise was very concerning so I took it to my local mechanic and he said the oil was dirty and changed it. I've put 20 miles on it since picking it up with no noise or CEL, which was coming on within the first couple miles before. I can confirm that the oil looked extremely dirty on the dipstick, but had only 5k miles on it over the last 13 months (oil/filter in signature). Has anyone heard of anything like this? I'd love to have been able to cut open that filter but it was already gone. Just curious if this sounds as unbelievable to anyone else as it does to me. BTW oil was right on the full line.
2016 Ram 1500 5.7 Hemi 30k
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400474
05/09/17 07:06 PM
05/09/17 07:06 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
I believe it. My 2008 Camry I believe has VVT but don't hold me to that. I use 5w30/10w30 without issues and no valvetrain noise. I attribute that to using FRAM ULTRA or MC filter wink
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400476
05/09/17 07:08 PM
05/09/17 07:08 PM
KingCake Offline
KingCake  Offline
Yes...oil level and quality greatly affect VVT systems. Both the solenoids and phasers. This is common knowledge. I suggest using a better filter like Fram Ultra. That might help. Your engine might have excessive blow by.
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400499
05/09/17 07:35 PM
05/09/17 07:35 PM
Missouri
gabriel9766 Offline
gabriel9766  Offline
Missouri
If it has the 3.6L they are bad for chain stretching if run low on oil and extended oil changes.
2015 Malibu LT 2.5L PPPP 0w20 46.1K
2007 Escape XLT 3.0L 5Q STHM 5w30/1Q MC full syn 5W20 115K
2010 Fusion SE 2.5L MC 0w20 110K
2008 Escape XLT 2.3L MC 5w30 187K
2007 Fusion SE 2.3L- 173.5K STHM 0W20
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400505
05/09/17 07:45 PM
05/09/17 07:45 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
It's a RWD VVT 4.6L Northstar.
Without a UOA....You don't know what condition the oil was in.
2001 Chevy Camaro L92/4L80E
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400640
05/09/17 10:44 PM
05/09/17 10:44 PM
pa
benjy Offline
benjy  Offline
pa
although your miles were not high your oil was in too long! 6 months is a good time frame especially if doing short runs where engine never warms enough to burn off moisture or any gas in the oil
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400689
05/10/17 01:29 AM
05/10/17 01:29 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Shearing down in grade can affect the effectiveness of the oil as a hydraulic fluid for the VVT system.
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400733
05/10/17 05:47 AM
05/10/17 05:47 AM
Warner Robins, GA
Warner Robins, GA
I've had the car 5 years and have always done an annual oil change on it so it was due, only reason I didn't do it before taking it to the shop is I figured whatever work they were going to have to do would involve an oil change. Go figure. My driving is 50/50 city/highway and the OLM was at 57%. I believe GM recommends annual regardless of what the OLM says. I'm just surprised that I was using good oil (car holds 7.5qts) and a good filter with reasonable mileage and had an issue.
Re: Oil causing problems in VVT engines [Re: DoubleWasp] #4400758
05/10/17 06:32 AM
05/10/17 06:32 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Yes, it causes nebulous "effects", but nothing is usually harmed.
Most oil actuated VVT setups have an extremely wide tolerance of different oil grades. May engage sooner/later but always seem to work
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Oil causing problems in VVT engines [Re: nwjones18] #4400898
05/10/17 09:49 AM
05/10/17 09:49 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
My old Camry had the stuck lock pin VVT issue plaguing many Toyotas. The infamous startup rattle, out of phase, etc. The controllers get plugged up if you don't change the oil on time, use a quality oil. And stay on the thin side. the veins are small, using thicker oils can cause VVT issue if things aren't squeaky clean. Fixed a few with this issue degunking the engine with whatever elixir or oil you prefer.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Oil causing problems in VVT engines [Re: KingCake] #4473520
07/28/17 11:19 PM
07/28/17 11:19 PM
Ca-Wa-Japan
udidwht Offline
udidwht  Offline
Ca-Wa-Japan
Avoid using anything made by Fram. Pure [censored].
Mobil 1 Extended Performance, WIX and/or NAPA Gold
Nothing else.
1994 Fleetwood Southwind Storm 28ft
P-30 454 TBI w/4L80E trans
1972 VW Westy hardtop (Type-4 2056cc)
2003 Toyota Highlander 2.4L
Re: Oil causing problems in VVT engines [Re: udidwht] #4473897
07/29/17 01:24 PM
07/29/17 01:24 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Nothing else.
That's total B.S. As I've used FRAM ULTRA on VVT engines without issues
