Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
BITOG using excessive CPU power?
by Kibitoshin
06/18/18 05:10 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Orion62, Revd, blinky1041, mostdecent, T1TN
65261 Registered Users
76 registered (2009Edge, Artem, andyd, badtlc, AandPDan, 2K2AcuraTL, 6 invisible), 1420 Guests and 39 Spiders online.
65261 Members
67 Forums
285507 Topics
Page 1 of 3 1 2 3 >
#4397932 - 05/06/17 05:09 PM O2 sensor will not break free
NavyVet88 Offline
Loc: Alabama
Ok im trying to replace the bank 1 upper o2 sensor on my buick. It's the one located right next to the firewall and that sucker will not break free for anything. I have soaked it in pb blaster, heated it up by running the car down the road till it was heated up enough.
All I know to do at this point is put a torch to it and go from there hoping it will work. If you guys have any suggestions, I'm open to them.
2013 Honda Civic LX 1.8L 127k M1 EP 0w20 with Fram XG7317
2003 Buick Century 3.1L 196k Maxlife 5W-30 with Fram TG3387A
#4397936 - 05/06/17 05:15 PM Re: O2 sensor will not break free [Re: NavyVet88]
FordBroncoVWJeta Offline
Loc: KS
Go get one of those little propane torches. Those work really good.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
#4397939 - 05/06/17 05:25 PM Re: O2 sensor will not break free [Re: NavyVet88]
Trav Offline
Loc: MA, Mittelfranken.de
You need a very deep 6pt impact socket, impact wobble and extensions with an impact gun or long 1/2 breaker bar, this will require cutting the wire off. Propane isn't doing much anything for that, you could use a real smoke wrench on the bung first.
If its that tight don't use a split socket it can round it off then you have a real fiasco. If you don't have the tools and torches take it to a mechanic it will probably save you a lot of grief.
#4397952 - 05/06/17 05:44 PM Re: O2 sensor will not break free [Re: NavyVet88]
dgunay Offline
Loc: Toronto
Try it with a cheater bar first.
If it doesn't work, get a propane torch.
2009 Acura CSX (K20Z2 Auto)
PUP 5w30 / M1-110 / Maxlife ATF
Koni STR.T Struts / Tein S-Tech Springs / 20mm OEM RSB
Cooper Zeon RS3-A / Continental WinterContact SI
#4397968 - 05/06/17 06:11 PM Re: O2 sensor will not break free [Re: NavyVet88]
NavyVet88 Offline
Loc: Alabama
I think I will let the mechanic have this one before it becomes more of a headache
#4397973 - 05/06/17 06:18 PM Re: O2 sensor will not break free [Re: NavyVet88]
Dadillac Offline
Loc: Woodbridge, NJ
I had an O2 that wouldn't budge. So I used an air hammer hitting it a few times. Came right out after that. If you have room try hitting it with a hammer, if you do not have an air hammer, down on the flat area.
Don
#4397985 - 05/06/17 06:49 PM Re: O2 sensor will not break free [Re: NavyVet88]
JTK Offline
Loc: Buffalo, NY
Agree with the above. Don't use a split socket or you'll round it. Been down that road. You'll really have to scrap the sensor by cutting the wire off, but a solid 6pt is the only way.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4398014 - 05/06/17 07:37 PM Re: O2 sensor will not break free [Re: NavyVet88]
andyd Online   content
Loc: Marshfield , MA
With great difficulty, I have used a box end. 7/8 on the one in the BMW. Saves the sensor
Thick oil is better grin2
#4398016 - 05/06/17 07:38 PM Re: O2 sensor will not break free [Re: NavyVet88]
Reddy45 Offline
Loc: USA
For some reason these offset type wrenches work really well on stubborn O2 sensors. I guess the design basically multiplies the torque.
https://www.harborfreight.com/3-8-eighth-inch-offset-oxygen-sensor-wrench-97177.html
#4398043 - 05/06/17 08:30 PM Re: O2 sensor will not break free [Re: NavyVet88]
GMBoy Offline
Loc: Texas
This right here is ALL I WILL USE. It works EVERYTIME and grips tight and takes all you can give it. The other one's don't hold a candle to this.
https://www.walmart.com/ip/O2-Oxygen-Sen...13=&veh=sem
#4398063 - 05/06/17 08:50 PM Re: O2 sensor will not break free [Re: NavyVet88]
copcarguy Offline
Loc: PA
I used a combination of a ratcheting wrench & offset wrench on the O2 socket. These gave additional torque rather than a ratchet.
You can also put a hose clamp over the end of the socket to prevent it from spreading under load.
#4398081 - 05/06/17 09:18 PM Re: O2 sensor will not break free [Re: NavyVet88]
NoNameJoe Offline
Loc: New York
If you don't already have a torch I've had good luck with the Bernzomatic TS8000 with the yellow MAP/PRO fuel. I recommend the universal hose extension by the same company (well the parent "Worthington") to get into tight angles.
If you don't need the O2 sensor what other people said makes the most sense, just snip the wires off and use a deep socket with a good breaker bar (25in). But if you can't get it loose you'll be screwed since you snipped the wires off.
#4398131 - 05/06/17 10:52 PM Re: O2 sensor will not break free [Re: NavyVet88]
RichardS Offline
Loc: Melbourne, Florida
Get an o2 socket from AZ, they're a loaner tool item.
Hit it with penetrating oil a few times, and let it sit over night.
Use a breaker bar on the wrench, and you should be able to get it out.
I did disconnect the vacuum line running from the rear of the motor to the master cylinder, that extra wiggle room was enough to negotiate around the bits I needed to get around to get it out of there.
I had a heck of a time getting that sensor out of mine, and the above is what finally got it free. I didn't heat it because I wanted to avoid potentially burning off the PB blaster I soaked it in the night before.
2008 Dodge Caliber SE 2.0 117k
4qt Imeditsu 0w-20, 1/2qt Mobil SS 5w-20 Fram HM
2003 Buick Century 107k
4.5q Havoline 5w-30 HM Fram XG
#4398135 - 05/06/17 10:54 PM Re: O2 sensor will not break free [Re: NavyVet88]
spasm3 Offline
Loc: North Carolina
Impact wrench, a good one. When you get it out, use the the anti-seize that comes with the new sensor.
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4398144 - 05/06/17 11:15 PM Re: O2 sensor will not break free [Re: NavyVet88]
JHZR2 Offline
Loc: New Jersey
Id do a heat and strike, heat and water quench, and heat and wax quench as options to get it out. After that I'd see if I could keep some permanent force on.
One car I put on ramps, then took my floor jack and finagled the ratchet to be constantly exerting force to loosen it. That actually worked well.
Page 1 of 3 1 2 3 >
