Separating toddlers from their parents?
by fdcg27
24 minutes 6 seconds ago
gm 8.6 truetrac
by Spitter
29 minutes 0 seconds ago
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
40 minutes 4 seconds ago
Rockauto 5% off
by Spitter
41 minutes 51 seconds ago
fumoto oil valve
by Santo
55 minutes 7 seconds ago
Grand solar minimum...
by ridgerunner
Today at 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
Today at 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
Today at 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
Today at 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
Today at 07:06 PM
Needing New Dipstick
by Geauxtiger
Today at 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
Today at 04:35 PM
Premium guard oil filters
by Jaha24k
Today at 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
Today at 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
Today at 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
Today at 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
Today at 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
Today at 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
Today at 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
Today at 01:38 PM
Santo, aligoodn, memyself, MichiganKid419, kaphouston
65273 Registered Users
105 registered (addyguy, 2002 Maxima SE, Aero540T, 2015_PSD, 9050lx, 2KBMW, 14 invisible), 1598 Guests and 30 Spiders online.
65273 Members
67 Forums
285621 Topics
Page 1 of 3 1 2 3 >
#4397844 - 05/06/17 03:15 PM Battery charging: How much driving after start?
LucasDK Offline
Loc: Denmark, Europe
Hi,
Are there some general rules of thumb for:
When you start the engine, how many minutes do I need to drive the car in order to charge the battery to the charging state just before starting?
Lucas
Toyota Hiace 2,4D (2L engine)
Toyota Corolla AE92, (4A-FE engine)
Ford Model A (3,4 liter engine)
#4397857 - 05/06/17 03:26 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
901Memphis Offline
Loc: Northern Kentucky
It would be impossible to give you a simple answer like you want. Starting doesn't take that much energy from a large battery, it's running accessories while the vehicle is off that brings the state of charge down.
It takes multiple hours to get the battery from 80-100%
The alternator will never fully charge the battery because it will not seek a high enough voltage for long enough to bring the specific gravity to the proper full range.
It's recommended to charge your battery on the grid with a quality charger every so often when you can maybe once a month or so.
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4397861 - 05/06/17 03:29 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
andyd Offline
Loc: Marshfield , MA
Too many variables for thumb. The Rat mostly has a dead battery, but it starts easily. I can jump it from the BMW and drive less than 2 miles to shop and it restarts? The alternator is putting out 14.5 v, I've checked that with a meter. The Bosch alternator on the 528e is set to only 14.1 V. It would likely need a jump. I keep a battery charger on the premises.
Thick oil is better grin2
#4397863 - 05/06/17 03:30 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
wrcsixeight Offline
Loc: california
It depends on the voltage the vehicles voltage regulator allows, and how long it takes to crank the engine.
When my AGM battery is truly 100% charged, it accepts 0.0x amps at 14.7v
If I start my v8 engine at this 100% state of charge, when amps at 14.7v taper back to 0.0x, the battery is again fully charged.
This takes about 45 seconds on my vehicle.
Note that most batteries are not fully charged when the engine is started and most vehicle charging systems on their own will not really be able to accomplish a true 100% state of charge. It is best to use a plug in charging source to squeeze in those last few % which can take hours. The 100% charged lead acid battery is twice as happy as the 98% charged battery and will likely live twice as long.
Far too many people act like alternators defy the laws of physics, nearly instantly recharging batteries and are a 'free' energy source. They can't, Don't, and are not. Not even when chromed and polished and spoken to lovingly.
#4397875 - 05/06/17 03:54 PM Re: Battery charging: How much driving after start? [Re: wrcsixeight]
DeepFriar Offline
Loc: Georgia
Little known fact: This same law applies to women.
#4397884 - 05/06/17 04:06 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
eljefino Offline
Loc: ME
The emptier your battery, the faster it will return to the state it was before starting. Its internal resistance is less.
My gear reduction starter motor is rated for 1.5 hp which is about 1000 watts or 80 amps. So with a 100 amp alternator it'll theoretically fill back up within seconds.
If you do, say, a paper route, your battery will sink to about 75% state of charge but reach a "new normal" and not go lower as it's insanely easy to go from 74% back up to 75% after a start.
This isn't great for it as it will sulfate, so a nice long drive will get it to 95% and a shore power charge every six months would bring it to 100.
#4397931 - 05/06/17 05:07 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
SilverSnake Online   content
Loc: Florida
If you are concerned about the state of your battery in any vehicle, you need accurate information. I recommend the Midtronics PBT300. It will tell you the state of your battery in seconds both in terms of voltage and CCAs. I use mine to monitor the state of the batteries in my vehicles at least once per week. It will also easily test your charging and starting systems.
https://www.amazon.com/Midtronics-PBT300...ords=midtronics
If your driving habits are not keeping the batteries in your vehicles at the optimum level, then a good smart charger will take care of the problem. I use the CTEK Multi US 7002 although there are many satisfactory options. Simply hook up the charger overnight and in the morning your battery should be at the optimum level. Severely discharged batteries may take longer. A lot of car guys I know keep a CTEK hooked up to their cars any time they are not in use. This practice will make your batteries last longer than they would otherwise.
http://smartercharger.com/products/batterychargers/ctek-multi-us-7002/
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
#4397943 - 05/06/17 05:31 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
Donald Offline
Loc: Upstate NY
With carburetors gone, most vehicles start right up and thus putting back into the battery what starting took out is done quickly. Obviously, headlights, defroster, heater fan may slow the process down. My pickup has a 1500w electric heater coil built into the heater system. I assume it consumes some power when it's on. For about 15 min after startup in cold weather.
2015 Ford F250 w/Powerstroke
#4398018 - 05/06/17 07:42 PM Re: Battery charging: How much driving after start? [Re: 901Memphis]
Ethan1 Offline
Loc: 'murica
It's not recommended to put your battery on a charger every month. That's preposterous. liar
#4398023 - 05/06/17 07:48 PM Re: Battery charging: How much driving after start? [Re: Ethan1]
Ducked Offline
Loc: Taiwan
They might not recommend it, because they know people wouldn't do it, so it'd [censored]-off the punters and so be bad commercial practice.
That doesn't mean it isn't good maintenance practice.
#4398025 - 05/06/17 07:49 PM Re: Battery charging: How much driving after start? [Re: Ethan1]
901Memphis Offline
I'd say at least a month if it's easy. If I had a garage with an outlet I'd be plugging up weekly
#4398079 - 05/06/17 09:10 PM Re: Battery charging: How much driving after start? [Re: 901Memphis]
yugrus Offline
Loc: ON, Canada
Would it hurt to have the battery maintained by the on-board smart charger on daily basis? I have my Tahoe rigged with on-shore power that supplies electric interior heater, seat heaters, block heater, oil pan heater, transmission heater and battery smart charger. Everything is controlled through three wifi timers. Smart charger gets power before anything else does, and I've made a habit to plug the power cord in whenever I park in the driveway. So it is natural for me to at least power the charger up. Am I doing a favor to the battery when I let it charge/maintain for 10-15 hours daily, or do I hurt something?
I'm really sorry for possibly hijacking the thread, but I couldn't rssist.
'14 Chevrolet Tahoe
'15 Mazda CX-5
#4398085 - 05/06/17 09:28 PM Re: Battery charging: How much driving after start? [Re: Ethan1]
blupupher Offline
Loc: Katy, Republic of Texas
Well, it was just recommended.
Topping off the battery monthly with a charger will give a lot of life to a battery.
1994 Honda VT1100C: Peak 15w-40/TG/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
#4398090 - 05/06/17 09:36 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
Linctex Offline
Loc: Waco, TX
Many people don't truly understand lead acid batteries.
No one here has even mentioned an "equalization charge" yet.......
#4398092 - 05/06/17 09:37 PM Re: Battery charging: How much driving after start? [Re: LucasDK]
yugrus Offline
Loc: ON, Canada
I guess I can contribute to the subject as well. GM has some charging system in trucks like mine that is more advanced then many. It constantly monitors battery's SOC, and adjusts alternator output accordingly. So with my daily battery charging regime, the alternator produces 14.7 for about 4 minutes, up to the point that computer realizes that the battery is fully charged. Then the voltage drops to 12.6v, and could stay there for 30 minutes of driving, maybe more. Then it goes up to between 13.7-14.7. Then, after a while it drops back to 12.6V.
That is when the ambient temp is above 5C or so. When it is cold though, the voltage would never drop below 13.7V, and goes as high as 15V, so the software doesn't care about SOC, maybe it is trying to keep the battery warm? In any case, GM charging system would totally give you credit for the fully charged battery under normal conditions, and it will get it back to full charge quite fast after the start-up.
'14 Chevrolet Tahoe
'15 Mazda CX-5
Page 1 of 3 1 2 3 >
