Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
25 registered members (2015Corolla, Char Baby, Astro14, BlakeB, DaleRider, Ablebody, 2 invisible), 716 guests, and 37 spiders.
Topics290,745
Posts4,849,459
Members66,033
Most Online3,590
Jan 24th, 2017
2011 Gen 3 Prius Misfire #4396379
05/04/17 04:34 PM
05/04/17 04:34 PM
Southeast
Rtstrider Offline OP
Southeast
Hello everyone I have a Toyota Prius 2011 3rd gen around 155k miles that is throwing a misfire code on cylinder 3. I ran a can of the gumout (looks like the seafoam can) tuneup through the gas tank and the code disappeared for a month or so. I just got these plugs https://shop.advanceautoparts.com/p/denso-iridium-tt-spark-plug-ixeh20tt-4711/10713048-P?navigationPath=L1*14923%7CL2*15034 and am replacing them tonight weather permitting. I'm hoping I'm on the right track. Next thing is should there be anything else I need to look at while I'm in there? Say try testing the ignition coil? I've read where there have been fuel injector issues on these also. Any input is much appreciated!
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396383
05/04/17 04:38 PM
05/04/17 04:38 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
You might want to swap the coil on cylinder 3 when you are changing plugs. I.E. use #2 on #3 and #3 on #2.
If you get another misfire, but on #2 cylinder, then the coil is suspect. If it's on #3, then it's something still common to that cylinder, like the fuel injector, wiring to the coil (or similar) or some mechanical issue.
Since you will have all the coils out to swap the plugs, it is no more work to put the #3 coil in another cylinder in case it's not an issue with the plugs.
network down, IP packets delivered via UPS -BOFH
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396393
05/04/17 04:54 PM
05/04/17 04:54 PM
Western S.C. since 1996
CR94 Offline
CR94  Offline
On priuschat.com, I've read of several cases of misfire due to clogging of the EGR system, especially including EGR passages in the manifold, and the EGR cooler (heat exchanger). Typically such clogging occurs at around the mileage you report. As I understand, the manifold passages can be cleaned, but the heat exchanger is difficult to unclog.
My 2011 Prius has not had that problem yet, at a little under half the mileage you have.
2011 Toyota Prius now at 92K
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396394
05/04/17 04:55 PM
05/04/17 04:55 PM
Southeast
Southeast
Actually wife says it's running rough at idle also. Should I go ahead and test the coils first or swap out the plugs then test?
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396438
05/04/17 05:59 PM
05/04/17 05:59 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Several years ago our 2001 Impala was showing a misfire code on one of the cylinders and sometimes running rough. The dealer said to try a can of Sea-Foam so I did that. The problem went away for six months and came back. I tried another can of Sea-Foam and the problem went away, but came back a little shorter than six months. I tried another can of Sea-Foam and the problem went away, and came back in even a shorter time. I started to think about what could be causing this. The car still had the original fuel filter on it, so I reasoned that it was possible that the fuel filter was pretty well clogged up and that the Sea-Foam was opening up enough passage for the fuel to flow fast enough again. So I changed the fuel filter and the problem never came back.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396534
05/04/17 08:10 PM
05/04/17 08:10 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Plugs first, if there is still an issue then further diagnose. Don't get the horse before the cart.
Re: 2011 Gen 3 Prius Misfire [Re: Trav] #4396544
05/04/17 08:23 PM
05/04/17 08:23 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
this.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396645
05/05/17 12:29 AM
05/05/17 12:29 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Have you been towing heavy loads with the Pri? sick
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396657
05/05/17 01:39 AM
05/05/17 01:39 AM
CA
The Critic Offline
The Critic  Offline
CA
Check the plugs if they are still original, but it is likely not your issue.
If you have access to a scan tool, command the EGR during light acceleration and see if the misfire can be duplicated. If it does, remove the manifold and replace it with the updated manifold as outlined by the service bulletin.
Also, as previously mentioned, the EGR pipe AND the valve are notorious for clogging up on these. They have a water-cooled EGR system. If the clog is bad enough, it can cause a misfire as well. Remove the EGR pipe and the EGR valve. Fully disassemble the EGR valve and clean it up well. The EGR valve can be removed w/o removing the EGR cooler if you remove one of the studs for the EGR cooler.
Some of these motors will develop headgasket leaks as well, but hopefully that is not your issue.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4396662
05/05/17 02:00 AM
05/05/17 02:00 AM
CR94 Offline
CR94  Offline
Or to summarize the EGR components I listed earlier and others The Critic did, the entire EGR system is suspect---pipe, cooler, valve, and manifold passages. Clogging of the manifold causes uneven distribution of EGR to the cylinders, which causes misfire.
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4400299
05/09/17 02:50 PM
05/09/17 02:50 PM
Southeast
Southeast
Alright guys I didn't have time to get to the car this past weekend. I'm going to give it a go this coming up weekend (hopefully). These spark plugs are very skinny! I'll keep everyone posted
edit: No towing with the prius
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4400319
05/09/17 03:09 PM
05/09/17 03:09 PM
CA
The Critic Offline
The Critic  Offline
CA
The spark plugs require a 14mm spark plug socket, not your usual 5/8". The windowshield wiper arms, cowl trim, wiper motor and cowl tray (lots of tiny bolts) will need to come out in order for you to access the plugs. Also, get the plugs from the dealer. They recently changed the spark plugs to a hotter temp range and none of the aftermarket catalogs (including Denso and NGK) reflect this yet.
Truthfully, your time is probably better spent on removing the EGR tube (4 nuts) and inspect that area before doing the plugs. If the EGR is plugged up, that is more likely to be your immediate problem.
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4400321
05/09/17 03:10 PM
05/09/17 03:10 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
As far as troubleshooting, I generally do not like more than one change at a time. The above suggestions are valid, and swapping coils is a good idea, as is checking the EGR. However, it is always nice to know the actual reason for the issue, just in case it pops up again.
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4404587
05/14/17 04:52 PM
05/14/17 04:52 PM
Southeast
Southeast
Alright changed the plugs and single cylinder 3 coil. The plug was ashed up and white. I pulled the egr tube cleaned it and the orifices it plugs into. The EGR system really wasn't too dirty. I also cleaned the throttle body which was basically spotless. We've driven about 20 miles and the code has come back. P0303. I'm thinking next step would be a fuel injector? Ideas?
Re: 2011 Gen 3 Prius Misfire [Re: Rtstrider] #4410053
05/21/17 01:50 AM
05/21/17 01:50 AM
CA
The Critic Offline
The Critic  Offline
CA
Do you have access to a scanner? Follow the instructions on the bulletin and command the EGR system under the conditions described. See if the misfires appear during those conditions. If not, then we can revisit other options.
