Originally Posted By: FlyPenFly
Excessive ZDDP will prematurely wear your engine.
Motorcycle oils like M1 V-Twin have a lot of zinc (1750 ppm) and I've never heard of them causing problems. Same with my regular Penrite brew of HPR-30 at 1570 ppm zinc, this is pretty much double the regular ILSAC zinc limits.
I think you would need silly high amounts to cause any ZDDP related problem.
Having said that, most Euro 0W-40 oils like M1 or Edge have about 1000 to 1100 ppm zinc, which should be plenty for most applications. For comparison M1 AFE has "only" 750 ppm zinc.
