Help a not-so-noob: shear stability theory.
by OilStasher - 12/12/19 08:03 AM
Latest oil purchase for Lawnmowers
by Snagglefoot - 12/12/19 07:44 AM
Old school bra
by whizbyu - 12/12/19 07:10 AM
Tricky flight ticket change fees
by Superflan - 12/12/19 07:10 AM
2019 Jeep Rubicon F&R Axle UOAs [5,000 Miles]
by 2015_PSD - 12/12/19 06:58 AM
Redline SL-1. Application warning
by BMWTurboDzl - 12/12/19 06:51 AM
My Forester CVT blew up
by IMPALA08 - 12/12/19 06:30 AM
2016 Titan XD Cummins, Schaeffers 9000 5W-40
by 06_lx - 12/12/19 06:09 AM
Brake pads and rotors
by mobilaltima - 12/12/19 12:26 AM
This oil looks interesting but not avail in US
by jkhawaii - 12/11/19 10:39 PM
Castrol Engine Shampoo (Oil Flush)
by adams355 - 12/11/19 10:03 PM
How Dumb can she get #2
by KeithS_NW_Ohio - 12/11/19 09:45 PM
Dodge Transmission
by Butterbean - 12/11/19 09:38 PM
Pay Raise
by KeithS_NW_Ohio - 12/11/19 09:17 PM
Mid-size SUVs for exploring/DD
by AZjeff - 12/11/19 09:05 PM
3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
14 Grand Caravan Broken Exhaust Valve
by cptbarkey - 12/11/19 07:48 PM
Put the winter tires on the Impala today.
by JimPghPA - 12/11/19 07:31 PM
lutvi20, Bazik, Lamasuna, berlinbai, SimpleGuy48
70111 Registered Users
93 registered members (alcyon, ARCOgraphite, Aero540T, 77GrandPrix, 2009Edge, 7 invisible), 1,456 guests, and 21 spiders.
Topics298,615
Posts5,139,181
Members70,106
Most Online3,589
Nov 2nd, 2019
2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 #4389834 04/26/17 06:55 PM
G
Gannet167 Offline OP
G
This oil was suppose to be changed at OCI of 7k miles. Through some confusion, it was unintentionally run much longer. This sample shows 6,700 miles, but in reality:
-13,287 miles on this oil
-Run for 2.5 years
-Much of it was in extremely cold conditions (-20 to -30)
-Many short trips of less than 2 miles where the engine never even got warm
-Probably 30+ hours of idling
-Approx 5k miles of highway
The first UOA at 101k miles on the engine showed nice results. These results show it was run far too long, although considering the conditions, this UOA makes sense and I suppose the oil performed relatively ok.
The oil is Motomaster Formula 1 Full Synthetic 5w30, which is rebadged Shell synthetic according to the MSDS. Filter was a Toyota house brand.
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4389888 04/26/17 07:45 PM
K
Kuato Offline
K
LOTS of idle time, short tripped and TBN pretty much done...makes sense the iron would be higher....might want to get back to 10k interval to compare.
Thick vs Thin test: 15k / 43k miles complete
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4390052 04/27/17 03:11 AM
SR5 Offline
Not as bad as I expected given the hard life, but TBN of 1.0 says it's time is up.
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4390145 04/27/17 06:57 AM
G
G
In the spirit of commenting with seat of the pants analysis to justify any and all OCI and type, I feel obliged to mention for what it's worth (which is nothing) that it "Ran Fine". In fact, it runs exactly identical with fresh full synthetic to how it did with the over used oil.
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4390151 04/27/17 07:01 AM
Chris Meutsch Offline
This is why I want a 4Runner.
2005 Honda CR-V EX, 278k
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4390298 04/27/17 09:59 AM
B
bigt61 Offline
B
Yeah, the mileage probably doesn't tell the true story. The harsh cold and extensive idling give more of a clue. While the oil was likely shot, it's impressive how the flashpoint and viscosity held up. I see only half a quart of make up - was the level down at the time of the oil change? Good post.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4390328 04/27/17 10:37 AM
G
G
The half quart was added approximately 2/3 through the OCI, around 8k miles. I didn't check the level at the time of the change, but a few tanks of fuel earlier (maybe 1000 miles prior) it was still full. It also looked fairly clean, probably something around the colour of dark maple syrup.
I have several rare earth magnets placed on the drain plug and on the filter. They're strong enough to require pliers to remove from a flat surface. They may have collected some iron and masked the true amount of metal in the oil.
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4390876 04/27/17 10:30 PM
sir1900 Offline
Looks fine for the most part given the fact you ran this for two Saskatchewan winters. I would go 10k max next time.
2015 Infiniti Q50
Mobil1 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + Mobil 1 M1-108A
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4390909 04/27/17 11:42 PM
F
FZ1 Offline
F
Think I would change the oil 1x per year.
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4391549 04/28/17 04:33 PM
G
G
Once a year and/or max 10k is my normal OCI. Even if I'm a little low on the mileage, given the cold temps effect on contaminating the oil and the fact that there's only a few months a year when changing it is possible with the weather, I'll normally make sure it gets done.
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: Gannet167] #4391622 04/28/17 06:24 PM
B
B320i Offline
B
Is this the 1GR-FE V6?
If so, my father's vehicle equipped with this engine did an equivalently long OCI over about 18 months. Except in his case, there was 3000 miles of maximum-load towing, and the rest was a 30min highway commute and weekend drives - in temperatures of the Australian Wet & Dry seasons, so always 80şF and above. Oil was Synpower 5w-40; the stuff with BMW approval.
Would've been interesting to compare the two types of extremes, had I bothered with a UOA.
'93 BMW 320i 217,000km - Valvoline Engine-Armour 15w40, Mann Filter.
Re: 2004 Toyota 4.0 V6 13300 Miles Motomaster Syn 5w30 [Re: B320i] #4391775 04/28/17 10:54 PM
G
G
It is.
