Hello BITOG community! I recently picked up a 2008 Corvette Z06 with 47k miles on it! Reading through the owner manual, there is no recommended service intervals for the following items:
Brake fluid
Clutch fluid
Differential fluid
Transmission fluid
Power Steering fluid
I plan on driving it about 3,000-5,000 miles per year. Car will not see any extreme use such as race track conditions, but will see some trips to the drag strip and back road aggressive driving.
The fluids are almost 9 years old, should I consider changing them out?
Brake fluid
Clutch fluid
Differential fluid
Transmission fluid
