Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
118 registered members (2015_PSD, 555, 97f150, 69Torino, 2012AccentSE, 64bawagon, 17 invisible), 2,125 guests, and 60 spiders.
Topics286,156
Posts4,903,136
Members67,565
Most Online2,967
Mar 10th, 2019
Leak from new radiator hose and new clamp #4380608
04/16/17 01:51 AM
04/16/17 01:51 AM
USA
garyfishell Offline OP
USA
Hi so I have a leak on a 2002 Ford Mustang V6 from the lower radiator hose specifically around the radiator clam and I can't figure out what's wrong. Whenever I tighten the clamp it stops the dripping so maybe that has something to do with it but I'm not sure.
The clamp is a screw clamp so not the stock one and it seems to leak all the time but again I'm not too sure.
Any help would be great, thanks!
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380613
04/16/17 01:58 AM
04/16/17 01:58 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Buy a tube of Permatex Aviation Forma Gasket. Use a new clamp.
Thick oil is better grin2
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380615
04/16/17 02:03 AM
04/16/17 02:03 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Ive had bad luck with screw clamps.
If you keep tightening the screw clamp be aware you can crack the plastic radiator. It might be worthwhile to check and make sure you didnt do just that.
Then while you have it open, and if its okay, slip on a gates powergrip clamp. They work like heatshrink tubing; you heat it to shrink it around the hose. When the car heats up they will adjust to the hose.
Measure the diameter of your hose and order the correct size.
http://www.gates.com/products/automotive...ing-chart-decal
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380617
04/16/17 02:07 AM
04/16/17 02:07 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That's your problem right there.
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380638
04/16/17 04:40 AM
04/16/17 04:40 AM
NC
BigD1 Offline
BigD1  Offline
NC
Had a few over the years that would not seal with the screw clamps. I just bought another screw clamp, and installed it 180 degrees, so I had two clamps on one hose. Drip or seep fixed.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380694
04/16/17 07:00 AM
04/16/17 07:00 AM
ME
eljefino Offline
eljefino  Offline
ME
Your hose is tired and compressed. A new hose could help.
But as said above I'd just smear RTV all over the rad nipple then reinstall the old hose and a new quality clamp.
Re: Leak from new radiator hose and new clamp [Re: eljefino] #4380701
04/16/17 07:23 AM
04/16/17 07:23 AM
Kansas
Kruse Offline
Kruse  Offline
Kansas
Did you read the subject line?
Re: Leak from new radiator hose and new clamp [Re: BigD1] #4380867
04/16/17 10:47 AM
04/16/17 10:47 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
^ works for me.
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380891
04/16/17 11:29 AM
04/16/17 11:29 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
This stuff works great for leaky hoses.
Permatex 85420 Permashield Fuel Resistant Gasket Dressing & Sealant, 2 oz Tube
https://www.amazon.com/Permatex-85420-Pe...esistant+Gasket
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380933
04/16/17 12:33 PM
04/16/17 12:33 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
What colt said; if you keep tightening a screw clamp, it will cut into the hose. You may need to get a new hose and use a factory style spring clamp, or get one like this from Napa:
https://www.napaonline.com/en/p/SME187208000S
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4380938
04/16/17 12:41 PM
04/16/17 12:41 PM
California
Kool1 Offline
Kool1  Offline
California
I have an 03 CRV with 200,000 miles. I've removed the factory hose clamps from the radiator numerous times and they are out of shape from my manhandling of them over the years. I replaced them with worm drive clamps and had leaks despite tightening and retightening them. I finally bit the bullet and bought these.
http://www.oreillyauto.com/site/c/detail...word=hose+clamp
I torqued them down with a torque wrench and never had another leak. I've had these constant tension clamps on for a about year and am very happy with the no leak results.
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4381007
04/16/17 02:58 PM
04/16/17 02:58 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
If you can wait a week or so there may be a free sample coming for Hylomar for Bitog members, that will cure the leak better than any other product you can buy and together with a constant tension clamp like the one kool1 posted it will be permanent and removable. Stay tuned.
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4382164
04/18/17 04:26 AM
04/18/17 04:26 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
If the hose is old, change it. I never had a leak issue using worm screw clamps.
The "thinking" man's friend.
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4432431
06/15/17 03:03 PM
06/15/17 03:03 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Using a gear clamp on a coolant hose will always leak eventually. As the hose heats up and expands, a gear clamp will not expand with it making it tighter, pinching the hose. Then as it cools it will loosen off again Repeat this a couple hundred times and it will leak for sure. This is why OEM use some kind of spring tension clamp, like a corbin. If a gear clamp has been used, recommend replacing the hose and using a proper clamp.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Leak from new radiator hose and new clamp [Re: garyfishell] #4434447
06/17/17 04:54 PM
06/17/17 04:54 PM
Trav Offline
Trav  Offline
Get a clamp like this one..
https://www.amazon.com/Breeze-Constant-S...sion+Hose+Clamp
And a tube of this..
https://www.amazon.com/Hylomar-172-148-U...ds=hylomar+blue
Remove the hose and wipe the nipple clean then smear a thin film of Hylomar on the nipple the push the hose on and tighten the clamp. It will never leak again guaranteed.
The nice thing with Hylomar is it does not make removing the hose in the future difficult. You will not use the whole tube but don't worry once you use this stuff you will never be without it and it wont go off in the tube like RTV and end up in the trash.
