Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
2007 Toyota Camry LE Alternator
by maverickfhs. 09/24/18 08:28 AM
AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
88 registered members (advocate, aquariuscsm, Astro14, ad244, 10 invisible), 1,930 guests, and 40 spiders.
Topics290,944
Posts4,852,970
Members66,062
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Need oil recommendation for high rpm Honda #4379361
04/14/17 10:17 AM
04/14/17 10:17 AM
MA
sds Offline OP
sds  Offline OP
MA
2011 Civic Si. ~71000 miles.
Unmodified for 60K miles, didn't consume much oil then (maybe 1/3qt every 5K). It was run with whatever oil I had on the shelf basically (PP or M1 EP 5W30, didn't matter).
Currently modified with bigger cams, slightly ported oil pump, slightly larger sump, and too many bolt ons to list, making about 240whp/165wtq, revving to ~8600RPM. The car is otherwise meticulously maintained.
As I live in the city, most of my drives consist of a cold start and maybe 1-5 miles of driving. This is exacerbated in the winter since I don't really drive except for around-town errands in Boston. I never push the motor on it until it's warm, but I do drive hard when I get the chance. I'm mildly concerned because it's burning a bit more oil now, on the order of 1/2-2/3 qt every 3K.
I know I'm not going easy on this motor with the combination of:
  • (sometimes very) cold starts and short trips
  • very high rpm
Is there anything I should be doing with regards to choosing my oil more carefully? I've been spoiled with all my Hondas as they haven't really cared what oil I use, but this setting is certainly a bit more extreme. Many thanks in advance!
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379372
04/14/17 10:30 AM
04/14/17 10:30 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Sounds like a fun car.
I would definitely up the HTHS (3.0+) as it sounds like this Si is pushed hard and probably trashes oil during high RPM runs.
Edge 0W40
M1 0W40
PP 0W40
PP Euro L 5W30?
All can be bought at Walmart for under $26 a 5qt jug.
'18 KIA Sportage LX AWD 2.4L: MSS 10w30
'13 Hyundai Santa Fe Sport 2.0T: EDGE 5w30
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379379
04/14/17 10:43 AM
04/14/17 10:43 AM
5600 feet elevation, Arizona
double vanos Offline
Edge 0w40
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379382
04/14/17 10:46 AM
04/14/17 10:46 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
M1, 0W-40 may be an excellent choice. It's HTHS is great, and it's excellent at cold temps too. Great all around oil.
FWIW, I use 15W-50 in my 407RWHP S2000 with 2.2L engine. But I am running 19.5 PSI boost without an external oil cooler. So the higher viscosity choice is partially to combat higher oil temps and very high loading.
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379410
04/14/17 11:27 AM
04/14/17 11:27 AM
MA
sds Offline OP
sds  Offline OP
MA
Okay great--headed off to Walmart to exchange the M1 EP 5W30 I have sitting here for some M1 0W40.
Would this oil also be appropriate for winter usage? (New England, think 0F to 40F).
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379432
04/14/17 12:08 PM
04/14/17 12:08 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I'd probably use Mobil 1 0W40.
God Bless Our Troops
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379434
04/14/17 12:13 PM
04/14/17 12:13 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Why wouldn't it be? It's a 0W you aren't going to get any better cold weather performance than that. Not that you'd need it above 0F though.
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379443
04/14/17 12:27 PM
04/14/17 12:27 PM
TX
robertcope Offline
robertcope  Offline
TX
I've run M1 0W-40 in my AP1 S2000 and NSX. It ought to work. I will admit that I've recently moved to Red Line 10W-30, but not for any good reason other than "I wanted to". Both cars see a fair amount of track time.
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379446
04/14/17 12:34 PM
04/14/17 12:34 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Edge 0w40 or Mobil 1 high mileage 10w40 for summer
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379463
04/14/17 01:07 PM
04/14/17 01:07 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
I'd use 40 weight. M1 0w40 and Rotella T6 5w40 are some good options.
Sounds like a fun car! Make sure you check your spark plugs and valve adjustment frequently.
8600 rpm is not that high at all, the weak point is the oil pump for k20z3. If you use k20a2 (plug & play) or s2000 (need modification) oil pump, it can rev up to 9000-9200 rpm safely.
2009 Acura CSX - PUP 0w20 / Fram XG7317 / Maxlife ATF
2018 Kawasaki Z650 - Motul 4T 5100 10w40 / OEM Oil Filter
Re: Need oil recommendation for high rpm Honda [Re: dgunay] #4379472
04/14/17 01:18 PM
04/14/17 01:18 PM
MA
sds Offline OP
sds  Offline OP
MA
I have an FD2 oil pump--the rev limit is there to protect the valvetrain with the bigger cams. Will do on the 40 weight--just bought some 0W40 and will probably just mix it 50:50 with the existing 5W30 that I have.
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379480
04/14/17 01:27 PM
04/14/17 01:27 PM
Toronto
dgunay Offline
dgunay  Offline
Toronto
Do you have stage 1 or 2 cams?
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379583
04/14/17 03:43 PM
04/14/17 03:43 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
OW40 will take care of you from PLUTO<--->SUN.
Re: Need oil recommendation for high rpm Honda [Re: wemay] #4379659
04/14/17 05:59 PM
04/14/17 05:59 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
That's an AWESOME analogy there Wemay!! Well played man.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: Need oil recommendation for high rpm Honda [Re: sds] #4379717
04/14/17 07:30 PM
04/14/17 07:30 PM
quebec canada
yvon_la Offline
yvon_la  Offline
quebec canada
Amzoil synthetic compressor oil ( probably sae20)you did say Honda rpm territory)
Truck driver
Nissan versa note s 2014 total classic 5w30(qc.ca) drivework oil filter
Page 1 of 3 1 2 3
