RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
107 registered (AITG, 2015_PSD, AP9, ARB1977, aquariuscsm, 10 invisible), 1463 Guests and 35 Spiders online.
65303 Members
67 Forums
285881 Topics
#4376487 - 04/10/17 09:09 PM 4R100 fluid
mobilaltima Offline
Loc: Golden Meadow, LA
the 4R100 in my F250 has been leaking, well not leaking but a few drops on the pan, since I got it from my cousin back in November. Crawled underneath yesterday with my torque wrench to see if any were loose, most of them were loose, I tried tightening them to 125 inch pounds and I could only get a few turns on one bolt before the gasket( cork gasket and looks to be the original) cracked and started pushing out from the side of the pan(way before the wrench clicked, and 125 inch lbs isnt much). I'll pick up one of the updated reusable Motorcraft gaskets from the dealer Thursday, and change the gasket and filter along with a drain and fill of the fluid. Hopefully it can last until I have time to pull it out and build it. I'm not hard on the truck, most shifts are at 2k rpm and the other day I floored it to 3k, I dont do it often, for being an old tranny with the miles on it it still shifts well. my question is, I've heard I can run Dexron III/Mercon in it, and also Mercon V. Some say not to use Mercon V in the 4R100, while others say Ford changed the formulation and its now compatible with the 4R100. I was thinking of going with Supertech for the Dex III/ Mercon or Supertech Mercon V, would that be a good choice or should I get a different brand? Are Supertech trans fluids good? Should I use Dex III or Mercon V? Thanks
Edited by mobilaltima (04/10/17 09:10 PM)
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
#4376493 - 04/10/17 09:17 PM Re: 4R100 fluid [Re: mobilaltima]
slacktide_bitog Offline
Loc: USA
Yes, Mercon V is now compatible with regular Mercon. I think the change was around 2005.
Nothing wrong with Walmart brand ATF, and the ST Mercon V should serve your needs with no problems.
#4376501 - 04/10/17 09:22 PM Re: 4R100 fluid [Re: mobilaltima]
PumpPusher Offline
Loc: Texas
I used Valvoline Mercon V. It is backwards compatible with our transmission. It wouldn't hurt to browse the forums dedicated to our trucks just to be safe.
#4376524 - 04/10/17 09:52 PM Re: 4R100 fluid [Re: slacktide_bitog]
Mantooth Offline
Loc: Southern Indiana
If the two are mixed, will that cause any issues? Reason I ask is because the last service on my 01 F250 was done at a shop and I don't know if he used Mercon or Mercon V. I'm planning on dropping the the pan to replace the gasket and filter. I plan on using Maxlife.
Edited by Mantooth (04/10/17 09:53 PM)
'14 Durango AWD 3.6,(mine) Hav ProDS 5w30/Napa Gold
'15 Journey AWD 3.6, (wife's) Napa Syn 5w20/Napa Gold
'01 F250 4x4 7.3PSD, 126k, M1 TDT 5w40/MC
#4376530 - 04/10/17 09:59 PM Re: 4R100 fluid [Re: Mantooth]
Loc: USA
here will be no problems doing this, and Maxlife is great stuff smile
Does your transmission have a drain plug? If not. consider the Dorman pan that has one, which will make future ATF changes easier.
#4377287 - 04/11/17 07:47 PM Re: 4R100 fluid [Re: mobilaltima]
mobilaltima Offline
I spoke to John Wood today, hes one of the most renowned 4R100 transmission builders in the country. He told me to drain the pan, change the filter and to also drain the torque converter (99 year models have a converter drain plug). He said to fill it up with 10 quarts of Maxlife syn trans fluid, then start the truck and as soon as its started to pour in 5 more quarts, shift through the gears and then check the level from there. While I will do that and 100% trust what he told me, should I go ahead and do a flush with the tranny cooler lines like I see so many people do? Example below
http://www.thedieselstop.com/forums/f47/...mission-198641/
#4378362 - 04/13/17 08:37 AM Re: 4R100 fluid [Re: mobilaltima]
rq375 Offline
Loc: PNW
That is the exact procedure I used about 10k miles ago when I installed a John Woods valve body and 6.0 trans cooler, FWIW I used Mobil 1 ATF as well.
#4557810 - 10/28/17 09:43 PM Re: 4R100 fluid [Re: mobilaltima]
Jimbo7_3L Offline
Loc: CA
I have a ATS 4R100 Stage 2 transmission in my 2003 F250 and want to change the ATF. Unfortunately I bought it used and don't know the type or brand of ATF in it. I called ATS and they said they normally recommend ATF +4 (yup, Mopar fluid!) in the 4R100!?! I questioned this and ATS said I could use Mercon V if I wanted but +4 was recommended. Being a Newbie, what do you experts recommend? Does the 2003 have a TC drain?
2003 F250 7.3L Diesel Crewcab Longbed
ATS Stage 2 with ATS deep pan
Diablo Tuner, EGT & Boost Gauges
RV Travel Trailer
#4557950 - 10/29/17 12:29 AM Re: 4R100 fluid [Re: Jimbo7_3L]
clinebarger Online   content
Loc: Fort Worth, Texas
Your transmission has aftermarket frictions in it, They probably do all their testing using ATF+4 & found it to work best (In their opinion) with the Pressure/Accumulation/Hydraulic modifications.
ATS likes to use Alto Red Eagle frictions, They are compatible with ATF+4 along with Dexron & Mercon fluids.
I would run a good synthetic Dexron/Mercon like Redline D4.
Your torque converter could be a aftermarket "Billet Cover" unit....You will need to visually check for a drain plug.
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4558275 - 10/29/17 10:42 AM Re: 4R100 fluid [Re: clinebarger]
Jimbo7_3L Offline
Loc: CA
Clinebarger,
Thanks for your comments. I heard back from the original owner and he said he used Royal Purple ATF +4 when he installed the trans. I will check for a drain plug. If there is no way to drain the TC would I be the safest to keep to RP ATF +4 or could I mix with any other high quality ATF +4? I read on the Dodge forums that RP is not licensed by Mopar.
Thanks!
RV Travel Trailer
#4558372 - 10/29/17 01:12 PM Re: 4R100 fluid [Re: mobilaltima]
Royal Purple get's roasted pretty good on this site, A lot of the "boutique" oil suppliers don't bother with OEM licencing. I have had customers use RP ATF with great success.
Now that you know what ATF was used......No reason not to stay with it
