OK gents - Got a question for yall:
I drive a Chevy Volt. It is an electric car with a gas engine that is fired up only when the main electric car drive battery is flat. The engine is a 1.4 liter, multi-port fuel injected normally aspirated engine, i.e., no turbo, no direct injection.
It has an OLM that bases oil life both on how the engine is run, and calendar time - no matter how little the engine runs, the oil has to be replaced at least every 2 years. The cat requires Dexos1 5W30 oil.
The way I use the car, the engine only runs about 3,000 miles every 2 years so I'm not wearing the oil out.
Question: What Dexos1 5W30 oil has the best "shelf life" not being used, but mostly just going along for a ride in the crankcase?
