Originally Posted By: spasm3
Originally Posted By: KitaCam
just curious...
If you add a quart to top up the oil level, does the OLM reflect the "refresh" of additives and show an increased number/percent?
The olm does not know the oil level or condition. It is only a calculator off the ecm using mileage, time, rpm and probably engine temps.
This does not apply to OP's GM car, but some OLMs actually have oil condition sensors. BMW and MB, for example, use a dielectric sensor to determine oil's condition. How well it works, I have no idea.
As far as oil level, again, many cars these days have electronic oil level sensors, but I don't know if that is used for OLM calculation purposes. Probably not.
I can tell for sure that Honda is purely calculated by mileage and vehicle outside temp, the actual calculations are done in the gauge control module. There are no sensors on the engine to change the calculation, there is no oil pressure, oil temp or level sensor.
I should also add the second gen TSX is also really bad for oil consumption. We were doing rings on pistons on them like there is no tomorrow. Again, caused by seized oil control rings due to carbon buildup.
