Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
97 registered members (2012AccentSE, Ag76, andyd, addyguy, AdditiveOCD, 14 invisible), 1,934 guests, and 69 spiders.
Topics286,446
Posts4,908,489
Members67,626
Most Online2,967
Mar 10th, 2019
STP dexron VI #4372220
04/05/17 09:29 AM
04/05/17 09:29 AM
Missouri
gabriel9766 Offline OP
Missouri
So I'm about 300 miles away from 25k and i want to change out some of the trans fluid in the Malibu. Wal-Mart stoped selling the maxlife atf i wanted to use. The Malibu has a drain plug and a check plug, so basically I'm doing a drain and fill of about 4 to 5 quarts. I got a deal on some stp dexron vi for $2.99 a Q through our parts store at work. So i grabbed 6 Q's. So how good of quality is this stuff?
2015 Malibu LT 2.5L PPPP 0w20 46.1K
2007 Escape XLT 3.0L 5Q STHM 5w30/1Q MC full syn 5W20 115K
2010 Fusion SE 2.5L MC 0w20 110K
2008 Escape XLT 2.3L MC 5w30 187K
2007 Fusion SE 2.3L- 173.5K STHM 0W20
Re: STP dexron VI [Re: gabriel9766] #4372232
04/05/17 09:46 AM
04/05/17 09:46 AM
GA
drtyler Offline
drtyler  Offline
GA
If it is a licensed Dexron IV product, the quality is fine.
Re: STP dexron VI [Re: drtyler] #4372260
04/05/17 10:16 AM
04/05/17 10:16 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Exactly. So long as it is Licensed/approved (not compatible or recommended) you will have no problems with the fluid.
There are a few that are not licensed that are OK to use (Redline D6 ATF comes to mind).
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: STP dexron VI [Re: gabriel9766] #4372269
04/05/17 10:28 AM
04/05/17 10:28 AM
stower17 Offline
stower17  Offline
I've been using it for top offs lately. Seeing as Amazon no longer has Havoline DEX VI for a good price, STP DEXVI has become my latest go to.
Works fine with no issues. It's licensed.
Re: STP dexron VI [Re: gabriel9766] #4372273
04/05/17 10:32 AM
04/05/17 10:32 AM
Missouri
Missouri
Re: STP dexron VI [Re: gabriel9766] #4372309
04/05/17 10:58 AM
04/05/17 10:58 AM
stower17 Offline
stower17  Offline
It also has the license number someone near the bottom of the bottle on the back.
Re: STP dexron VI [Re: gabriel9766] #4372369
04/05/17 11:59 AM
04/05/17 11:59 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Last month we did a drain & fill on our 2015 Sonic . I think it has the same transmission as your car .
I used almost 5 quarts of Havoline Dexron VI I bought back when they had it for a good price .
Our local Walmart has shown ( on their web site ) to be out of stock on Valvoline MaxLife . It recently showed to be available online . I ordered 2 one gallon jugs , delivered to the local Walmart .
Best I can tell , MaxLife is recommended for Dexron VI , but not licensed . Valvoline does sell a Dexron VI in a blue bottle , that I think is licensed ?
Thinking about using the MaxLife in our 1991 Caprice , not our 2015 Sonic .
I would certainly buy STP Dexron VI for $ 2.99 , if I could get my hands on it .
God bless
Wyr
Wyr
God bless
Re: STP dexron VI [Re: gabriel9766] #4372401
04/05/17 12:19 PM
04/05/17 12:19 PM
GA
drtyler Offline
drtyler  Offline
GA
You're good to go then. For $2.99 per quart, that's a great deal!
Originally Posted By: gabriel9766
Re: STP dexron VI [Re: WyrTwister] #4372502
04/05/17 02:01 PM
04/05/17 02:01 PM
Missouri
Missouri
God bless
Wyr
Did you do a drain and fill and measure the fluid. Or did you check the fluid level with the check plug?
Re: STP dexron VI [Re: stower17] #4533421
10/03/17 10:47 PM
10/03/17 10:47 PM
GA
acme Offline
acme  Offline
GA
The label on the back of STP Transmission fluid VI shows the same wording as Super Tech. It must be good shocked
Re: STP dexron VI [Re: gabriel9766] #4533620
10/04/17 09:49 AM
10/04/17 09:49 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Dex VI is a tight spec for approval so I believe it should be of a high quality. Use it with confidence
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: STP dexron VI [Re: gabriel9766] #4533883
10/04/17 01:37 PM
10/04/17 01:37 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
God bless
Wyr
Checked with the drain plug , idling in park .
Best of luck to you , :-)
Wyr
God bless
