Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Geardaddies, 01ws666, ariefnrst, tcoffin014, Schm1d
66658 Registered Users
105 registered members (4WD, ArrestMeRedZ, andyd, Alfred_B, 28oz, 13 invisible), 1,952 guests, and 38 spiders.
Topics294,983
Posts4,925,346
Members66,658
Most Online2,553
Oct 27th, 2018
Residential vs Industrial exterior paints? #4371940
04/04/17 07:04 PM
04/04/17 07:04 PM
IL
Vern_in_IL Offline OP
IL
What is the difference?
Why is one for "industrial use only"? For example the paint I buy from NOW(National Oil Well) are far better(Tnemec brand) than paints I can get from Ace Hardware or Do-it-Best stores.
Re: Residential vs Industrial exterior paints? [Re: Vern_in_IL] #4371962
04/04/17 07:37 PM
04/04/17 07:37 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Maybe industrial paints are formulated better but have VOC's that require proper handling out of the scope of homeowners.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Residential vs Industrial exterior paints? [Re: Vern_in_IL] #4371983
04/04/17 08:25 PM
04/04/17 08:25 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
Take a look at the ingredients. I think they still use lead paint in some exterior applications. Can't use that in residential applications. Lead paint was really good, that's why it was so popular for so long before it was finally banned.
Re: Residential vs Industrial exterior paints? [Re: Vern_in_IL] #4371984
04/04/17 08:26 PM
04/04/17 08:26 PM
Central Coast, Calif.
tom slick Offline
tom slick  Offline
Is it the same type of paint? Latex? Alkyd? Epoxy? Urethane? Etc.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Residential vs Industrial exterior paints? [Re: Vern_in_IL] #4371990
04/04/17 08:35 PM
04/04/17 08:35 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
If it matters for your application, check to see if either of them have any UV protection.
Re: Residential vs Industrial exterior paints? [Re: tom slick] #4371998
04/04/17 08:49 PM
04/04/17 08:49 PM
IL
IL
Aluminum paint for oil field tank batteries/propane tanks.
Re: Residential vs Industrial exterior paints? [Re: Vern_in_IL] #4372397
04/05/17 11:19 AM
04/05/17 11:19 AM
MI
doitmyself Offline
doitmyself  Offline
MI
I have access to industrial use only products at work, but am no expert on the OP's question. I would imagine that there are many reasons, but most revolve around consumer,product, and mfg. liability. Sometimes the only difference between the two products is the actual printed labeling on the container. In other instances, the industrial product requires a more trained person to use it correctly for various reasons: safety, applicability/success, application equipment, etc.. At a hardware store, the consumer only has to decide which color of Rustoleum they want. With an industrial product, they may have to decide on a dozen or more different primer, topcoat,and additive choices and a dozen different ways to apply it. Consumer products tend to be dumbed down to meet the needs of the audience at hand. Consumers often don't recognize the value of a product that is initially much more expensive.
Again, there are many reasons. And, "industrial use only" does not always guarantee a better product. Contractor grade materials are often marginal products offered to professionals that need something just "good enough" for the situation at hand. The term "idiot proof" comes to mind when I compare consumer vs. industrial grade products.
Re: Residential vs Industrial exterior paints? [Re: Vern_in_IL] #4447149
07/02/17 03:28 AM
07/02/17 03:28 AM
wa
Exhaustgases Offline
wa
Yeah VOC's, first off its safer to have the home owner using it, as they will never paint a huge battle ship or aircraft carrier, nor a huge steel bridge and that is all done outside, with zero concern about VOC or anything else.
You will never see kids water colors used on any of those items. Because the water will cause under surface rust or freeze blisters from trapped water, thus peeling, I see it on water painted cars all the time.
