New Magnefine Power Steering Filter? R038M-P 3810
by huh
03/24/18 01:30 AM
97 4L60E 213K Miles ~ P1870 Code, Hard 1-2 Shift
by dogememe
03/24/18 01:22 AM
Dump or Pump
by TheLawnRanger
03/23/18 11:38 PM
2007 Corolla; low idle and overheat condition
by Rolla07
03/23/18 11:32 PM
Coolant dye - Interdynamics 375CS Radiator/Coolant
by Ndx
03/23/18 10:15 PM
Amsoil OE
by 02z
03/23/18 09:07 PM
Pennzoil Rebate Question
by klt1986
03/23/18 08:47 PM
Electrician's advice? I need help!
by 14Accent
03/23/18 08:40 PM
Disposing of coolant?
by HoosierJeeper
03/23/18 08:22 PM
Chisel Tattoos.
by Silk
03/23/18 08:06 PM
Transmission stuttering on takeoff?
by zeke1985
03/23/18 07:40 PM
DIY Phone and tablet repairs ?
by Shannow
03/23/18 07:11 PM
Why do women despise other good looking women ?
by Mr Nice
03/23/18 07:09 PM
DIY catch can material?
by yugrus
03/23/18 07:06 PM
UAO Mobil1 AFE 0W20 2015 Malibu 4,995 miles
by gabriel9766
03/23/18 06:49 PM
Replacement Radiator
by Ndx
03/23/18 06:29 PM
Jump-N-Carry JNC318
by Trav
03/23/18 06:13 PM
Remote Transmission Filter
by Nick1994
03/23/18 06:07 PM
How do you like your steak cooked?
by ZZman
03/23/18 05:42 PM
Coolant Question - Can it degrade or go bad?
by maverickfhs
03/23/18 04:12 PM
Nathan75, NXFan, Searay18, bobgafner, Billis59
64536 Registered Users
29 registered (Bottom_Feeder, BrewCityR, BobsArmory, 40w8, Char Baby, 4 invisible), 766 Guests and 97 Spiders online.
64536 Members
68 Forums
280332 Topics
#4371546 - 04/04/17 11:10 AM Compact size bypass filter
oilymikey Offline
Loc: Minnesota
Does anyone manufacture a small bypass filter?
I've used the Amsoil 6" filter in the past but I would like one that occupies less space; for example, something about the size of a PF454.
I would cheerfully trade more frequent element changes for compactness.
Thanks... Mike
#4380573 - 04/16/17 12:25 AM Re: Compact size bypass filter [Re: oilymikey]
xtell Offline
Loc: ohio
The smallest spin on bypass filter that I know of is a Baldwin B296. It is 3-11/16 wide and 3-7/8 long. You would need to get a 5/8-18 threaded mount for it. There is a oil flow restrictor built into the filter already (around .060 in size). However, if you want to slow the flow down even further you would need to install a .030 to .045 restrictor fitting somewhere, preferably before the filter. I personally use the .030 size on my bypass units. Hope this helps you out.
#4381138 - 04/16/17 06:39 PM Re: Compact size bypass filter [Re: oilymikey]
oilymikey Offline
Loc: Minnesota
xtell, that is the specific info I've been searching for... I'll check it out. Thanks for providing it!
#4381276 - 04/16/17 10:25 PM Re: Compact size bypass filter [Re: oilymikey]
rrounds Offline
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
#4684357 - 03/04/18 05:41 PM Re: Compact size bypass filter [Re: rrounds]
beanoil Offline
Loc: Midwest, Illinois
Originally Posted By: rrounds
TSC closed out all the Fram filters for 79 cents. No more PB50 there.
Napa 51050 is the same. Both are about the size of a PH8, and have a built in restrictor.
Not exactly on the small size for the OP.
Edited by beanoil (03/04/18 05:41 PM)
beanoil: Tough under heat, real dirty afterwards.
#4691262 - 03/11/18 10:02 AM Re: Compact size bypass filter [Re: oilymikey]
Linctex Offline
Loc: Waco, TX
Have you looked at the Fram HD PB50?
The Fram P3317 is the shorter version of the PB50
(about the same size as the Baldwin B296 mentioned earlier)
The Hastings LF445 is just a touch over 3" long,
making it the smallest spin on by-pass filter that I know of.
I think it crosses to the Baldwin B222:
