125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
19 registered members (dlundblad, dirtymudder, asand1, emod, honeeagle, Ether, 2 invisible), 755 guests, and 37 spiders.
Topics290,617
Posts4,847,579
Members66,011
Most Online3,590
Jan 24th, 2017
Oil for engine break in? #4368668
03/31/17 08:04 PM
03/31/17 08:04 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
So a new gm goodwrench tbi engine is about to be installed but the manual that came with the engine says nothing about breaking it in. I found a break in procedure from gm for there 290hp crate engine. I am going to do that break in procedure on this tbi engine. The break in procedure states not to use synthetic oil for break in just a standard non synthetic 10w30. I was going to use delo 10w30 xle but i noticed its a synthetic blend. Is that oil ok to use or should i just use pyb 10w30 or something? i was going to use the delo because the voa indicate a higher amount of zddp that would be good for break in.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Oil for engine break in? [Re: joegreen] #4368676
03/31/17 08:14 PM
03/31/17 08:14 PM
east tn
ebr1190rx Offline
ebr1190rx  Offline
east tn
Drive to parts store. Look on shelf for oil that says break in. When I was a gearhead we always used comp cams bespoke break in oil. No failures ever.
The artist formerly known as Line Array Nut.
Re: Oil for engine break in? [Re: joegreen] #4368678
03/31/17 08:17 PM
03/31/17 08:17 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I'd prob get some Formula Shell at Home Depot for $10/jug on sale right now:
http://www.homedepot.com/p/Formula-Shell-10W30-160-fl-oz-Motor-Oil-550022699/204999667
If you stop in at Napa for atf (different thread) might as well check to see if they can source some Peak 10w30 for cheap:
https://www.napaonline.com/en/p/PMRCONV10W30
Re: Oil for engine break in? [Re: joegreen] #4368686
03/31/17 08:22 PM
03/31/17 08:22 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
If its a flat tappet cam i'd use delo, rotella, some high zinc oil. If roller cam i'd not worry too much. I don't see why you could not use syn, but its a waste. I'd change the oil after it ran 20 minutes to and hour, and dumping syn that early is a waste of money.
Btw if it is a flat tappet cam, don't let it idle, keep it above 2000rpm for 20 minutes or so varying the rpm.
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: Oil for engine break in? [Re: joegreen] #4368711
03/31/17 08:46 PM
03/31/17 08:46 PM
NY
joegreen Offline OP
joegreen  Offline OP
NY
It is a flat tappet engine. The motor is going in my dads truck so im trying to tell him what to buy over the phone.
1978 Chevrolet k20
Re: Oil for engine break in? [Re: joegreen] #4368748
03/31/17 09:47 PM
03/31/17 09:47 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
I would run Valvoline VR-1 10W-30, but good luck finding an AutoParts store that stocks it these days.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Oil for engine break in? [Re: joegreen] #4368755
03/31/17 10:01 PM
03/31/17 10:01 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You have one shot and only one at breaking that cam in don't skimp on using a dedicated break in oil.
If the engine uses a distributor or has a plug in the distributor hole use a dummy shaft and electric drill to fill the filter and bring the oil pressure up prior to cranking.
Vacuum fill the cooling system and set the timing as close as possible so you can bring the RPM up to 2000-2500 right after she fires and has full oil pressure. Run it for 20 minutes then dump the oil and refill with another load of break in oil leaving the filter in place.
Run the engine for an hour at varying RPM (you can drive it) keeping it off idle as much as possible then change the oil and filter, use high zinc content dino of the first 3K before going to synthetic.
Run an oil with at least 1000 ppm zinc 1200 would be ideal.
https://www.summitracing.com/search/product-line/joe-gibbs-driven-br-break-in-motor-oil
2cents
Re: Oil for engine break in? [Re: joegreen] #4368895
04/01/17 05:37 AM
04/01/17 05:37 AM
Sunny Florida
SteveSRT8 Online content
SteveSRT8  Online Content
Sunny Florida
Many cam jobs are ruined by cranking the engine excessively with no start.
That's where you will love a modern engine with no distributor. Once you get everything hooked up correctly it will start immediately with little cranking.
Liberal use of assembly paste is all you got for the first few rotations...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Oil for engine break in? [Re: joegreen] #4369006
04/01/17 09:39 AM
04/01/17 09:39 AM
Central Iowa
TiredTrucker Offline
Central Iowa
Aren't the Goodwrench crate engines run a little to ensure that they work before shipping out? So they should have gotten lube throughout during that process and went thru the initial few minutes of break in. Should be pretty much plug and play. Only got one GM crate engine in the past, in 1999. Just dropped it in and drove it. Changed oil after about 8 hrs of initial operation and never had a problem with the engine. All it ever got was a conventional 10w30. Pickup didn't last all that much longer, but the engine was fine.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: Oil for engine break in? [Re: joegreen] #4369065
04/01/17 11:09 AM
04/01/17 11:09 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
CK-4 has changed the game on ZDDP content in diesel oils. If dual rated, say CK-4/SN, you'll find a maximum of .08 phosphorus. If only CK-4, or CJ-4/SM likely it should still be at .12.
Read the label when using diesel oils from this point on in break-in and flat tappet motors.
http://www.fleetequipmentmag.com/demistifying-new-engine-oil-categories-compatibility-ck4-fa4/
I second VR-1 10w30, even if you have to order it in.
beanoil: Tough under heat, real dirty afterwards.
Re: Oil for engine break in? [Re: beanoil] #4369144
04/01/17 12:21 PM
04/01/17 12:21 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
That still depends upon SAE grade. The "ILSAC" grades, which are 0w-30, 5w-30, and 10w-30 have to follow the lower phosphorus limits if CK-4/SN. That doesn't apply to the higher grades. I just went through a stack of API appendices, ballot results, and position papers from oil companies to the API to get some handle on that, since they don't have one definitive document on the matter, quite like they did to describe the old loophole.
Of course, none of this prevents an oil company from making a low phosphorus 15w-40, be it CK-4, CK-4/SN, or completely uncertified.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Oil for engine break in? [Re: joegreen] #4370235
04/02/17 05:18 PM
04/02/17 05:18 PM
Trav Offline
Trav  Offline
Re: Oil for engine break in? [Re: joegreen] #4370350
04/02/17 07:53 PM
04/02/17 07:53 PM
Florida
artificialist Offline
Florida
Since flat cam break in can be risky, I would look into Brad Penn break in oil. It has extra ZDDP, is conventional, and has only enough detergent to be driven 500 miles.
Royal Purple also makes a non-synthetic break in oil with similar properties.
Joe Gibbs also has something similar.
You should be able to get one of those oils at your local speed parts shop.
2010 Lancer Ralliart Sportback
Re: Oil for engine break in? [Re: joegreen] #4370358
04/02/17 08:02 PM
04/02/17 08:02 PM
oh
roadrunner1 Offline
roadrunner1  Offline
oh
https://jdparts.deere.com/partsmkt/document/english/pmac/5452_fb_BreakInOil.htm
If you have a Deere dealership nearby this oil will do the job for break-in.
'15 F350 6.7
Re: Oil for engine break in? [Re: joegreen] #4370361
04/02/17 08:03 PM
04/02/17 08:03 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
Motorcycle oil has a lot of zinc, like 1700ppm or so. I have not tried it but i see no reason you could not use that as a break-in oil. Not cost effective, except against the cost of beak-in oil.
