Pennzoil Platinum at Walmart
by TheLawnRanger
Yesterday at 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
Yesterday at 10:45 PM
Whats the odds..
by Eric Smith
Yesterday at 09:51 PM
Who can relate?
by Reddy45
Yesterday at 09:43 PM
No more oil changes
by goodtimes
Yesterday at 09:19 PM
Separating toddlers from their parents?
by fdcg27
Yesterday at 08:50 PM
gm 8.6 truetrac
by Spitter
Yesterday at 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
Yesterday at 08:34 PM
Rockauto 5% off
by Spitter
Yesterday at 08:32 PM
fumoto oil valve
by Santo
Yesterday at 08:19 PM
Grand solar minimum...
by ridgerunner
Yesterday at 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
Yesterday at 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
Yesterday at 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
Yesterday at 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
Yesterday at 07:06 PM
Needing New Dipstick
by Geauxtiger
Yesterday at 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
Yesterday at 04:35 PM
Premium guard oil filters
by Jaha24k
Yesterday at 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
Yesterday at 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
Yesterday at 03:55 PM
Shassis, Santo, aligoodn, memyself, MichiganKid419
65274 Registered Users
33 registered (bsmithwins, claluja, Bjornviken, bdcardinal, 2015_PSD, Bandito440, 1 invisible), 970 Guests and 38 Spiders online.
65274 Members
67 Forums
285629 Topics
#4360399 - 03/22/17 03:38 PM SAE 30 Grade Racing oil formulation
MolaKule Offline
Loc: Iowegia - USA
Here is a SAE 30 Grade Semi-Synthetic Racing oil (ONLY) formulation (Values rounded up or down);
Zinc - 1600 ppm
Phosphorus - 1450 ppm
Calcium - 2200 ppm
Sodium - 350 ppm
Silicon - 5 ppm
Vis @ 100C (cSt) 12.35
Flash Point 261C
Pour Point -35C
VI 150
Not to be used in vehicles with Catalytic Converters. cool
Edited by MolaKule (03/22/17 03:41 PM)
#4360403 - 03/22/17 03:41 PM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
Shannow Offline
Loc: 'Stralia
Molakule,
in "SAE30", are you suggesting that as per J300, there's no VII, or as it's a racing oil is the "W" not a design parameter.
No problems with that level of zinc with spalling/pitting ?
It's a little in the face of a number of myths, looks good.
#4360422 - 03/22/17 04:11 PM Re: SAE 30 Grade Racing oil formulation [Re: Shannow]
MolaKule Offline
Loc: Iowegia - USA
Originally Posted By: Shannow
Molakule,
The customer wanted a "narrow" SAE 30 grade and therefor does not contain any VII's.
VI and viscosity is determined primarily by the mix of base oil types and viscosities.
Label will indicate that as a racing oil, it is to be changed after the daily racing event, and further indicate that a conventional daily driver oil should be installed prior to storage.
One of the tests done was on a blueprinted 625 Hp V8 engine (very expensive test btw) for hours at varying RPM under varying loads. Crankshaft, cams and bearings were examined microscopically after teardown and no spalling or corrosion pitting were indicated.
Edited by MolaKule (03/22/17 04:15 PM)
#4360434 - 03/22/17 04:22 PM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
BrocLuno Offline
Loc: Kalifornia Kollective
I like it. Seems like racing oils I have run into in the past ... Problem is hot shoes like to try to run it on the street duh
Edited by BrocLuno (03/22/17 04:23 PM)
#4360479 - 03/22/17 05:14 PM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
BTW, friction modifiers are ashless. You don't want anymore ash forming on spark plugs and valving than necessary.
At the high temps and high air flows involved in the test engine, little ash was formed.
#4360884 - 03/23/17 04:14 AM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
Shannow Offline
Loc: 'Stralia
Nice, thankyou for the additional information Molakule.
#4360937 - 03/23/17 06:15 AM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
userfriendly Offline
Loc: LaFinDuMonde
I'll guess it a 15W30, HTHS 3.55 and density .850
#4361865 - 03/24/17 12:02 AM Re: SAE 30 Grade Racing oil formulation [Re: userfriendly]
MolaKule Offline
Loc: Iowegia - USA
HTHS is 3.7
TBN is 7.5.
#4361888 - 03/24/17 02:05 AM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
SR5 Offline
Loc: Down Under
Another great oil from MolaKule
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4361891 - 03/24/17 02:32 AM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
SR5 Offline
Loc: Down Under
Originally Posted By: MolaKule
Zinc - 1600 ppm
Calcium - 2200 ppm
Sodium - 350 ppm
Silicon - 5 ppm
That makes sense to me. Many of my friends and I ran Penrite HPR 30 in our cars and bikes for years, both leaded and unleaded fuel, but none had cats. The HPR 30 has 1570ppm Zinc, and I never heard of any problems, even after years of usage.
I notice you have a touch of sodium there, what is that for ? You have ample TBN for an oil that should be changed after a single day at the race track.
Just for arguments sake, if somebody did live in a very hot climate (me) so no winter start issues. Plus they had an older cat-less pushrod car (younger me), so no zinc issues. Then they went against the advice on the label and ran the oil for 6 months say (younger foolish me), would you expect any issues with the engine / oil ? Maybe it has limited dispersant levels to hold the soot in suspension ? But I'm just guessing.
#4362173 - 03/24/17 11:40 AM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
MolaKule Offline
Loc: Iowegia - USA
Quote:
Sodium 2-mercaptobenzothiazole can be used as a metal deactivator to keep metals from reacting with other compounds, and to help retard oxidation.
Some sodium compounds such as sodium dibutyl dithiocarbamate SDDC) are used as another anti-wear agent in lieu of conventional AW compounds. SDDC shows a low fricton coefficient with good polarity since being a dithio-type compound, has sulfur atoms for polarity enhancement.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/2764914/Alternative_Detergents_%22S#Post2764914
#4362618 - 03/24/17 09:22 PM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
SR5 Offline
Loc: Down Under
Thank you !
#4362620 - 03/24/17 09:28 PM Re: SAE 30 Grade Racing oil formulation [Re: SR5]
Shannow Offline
Loc: 'Stralia
great question, I would like to know too...
#4457374 - 07/12/17 03:19 PM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
1JZ_E46 Offline
Loc: Oregon
Where can I buy it?
2007 BMW X5 4.8i, 105K: Castrol EDGE 0W-40, Mann
2012 Mini Cooper, 45K: Castrol EDGE 0W-30, Mann
#4483920 - 08/09/17 05:17 PM Re: SAE 30 Grade Racing oil formulation [Re: MolaKule]
DWC28 Offline
Loc: Houston, TX
Lubrizol used to run a lot of sodium in their motor oil packages. No one else at the time did.
