Detroit 51 series 2 cycle diesel
by Red91. 03/25/19 01:54 PM
Rust repair cost
by supton. 03/25/19 01:41 PM
MANNOL ATF Multivehicle
by Ether. 03/25/19 01:17 PM
Welcome to Dusseldorf... err... Edinburgh.
by Quattro Pete. 03/25/19 01:07 PM
1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
121 registered members (555, 53' Stude, 14Accent, 1nighttrain, 4WD, 928, 12 invisible), 2,276 guests, and 63 spiders.
Topics286,403
Posts4,907,692
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Rotella no longer gas engine rated? #4359262
03/21/17 10:08 AM
03/21/17 10:08 AM
European Union
Atesz792 Offline OP
Atesz792  Offline OP
European Union
Originally Posted By: Ramblejam
Incorrect, guys. This keeps coming up over and over again here lately, so I'll put it in big bold letters... wink
T6 MULTI-VEHICLE 5w-30 IS NOW THE ONLY ROTELLA THAT WILL CARRY AN API GASOLINE SERVICE CATEGORY MOVING FORWARD.
Taken from another thread on this forum. What happens now when someone new comes here asking which oil they should run? What will current Rotella users do?
2004 Suzuki GS500F
2006 Renault Megane 1.5 dci
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359287
03/21/17 10:28 AM
03/21/17 10:28 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Lets wait for some VOAs or other solid information on what the additive packages actually ARE.
Many people running Rotella in gas engines are doing so in an engine that doesn't need an SM or SN rating- that's one of the whole points of even using Rotella in a gas engine. If you're using it "off-label," then what do you care what rating it carries? For vintage big-block or other flat-tappet / big valve-spring engines, the "diesel-only" T6 5w40 should be fine (pending looking at a VOA to see if there's any benefit). For newer engines, the 5w30 that still carries the gas engine rating should be fine.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359290
03/21/17 10:34 AM
03/21/17 10:34 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
How many times do we disobey the speed limit?
  • 2017 Toyota Sienna
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359325
03/21/17 11:25 AM
03/21/17 11:25 AM
Ohio
Dave Sherman Offline
Ohio
The current T6 5W-40 data sheet on Shell's website still has SL and SM listed.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: Rotella no longer gas engine rated? [Re: 440Magnum] #4359368
03/21/17 12:12 PM
03/21/17 12:12 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Bingo - If I decide to run off-label it's my decision. If the VOA/UOA's come back similar to old, who cares what the label says.
How many times do we break the speed limit? More times in a day than I have fingers and toes. But usually not for prolonged periods. Plus, everyone around me is running 5%~15% over. What am I supposed to do, slow everyone down ... laugh
Re: Rotella no longer gas engine rated? [Re: Dave Sherman] #4359370
03/21/17 12:13 PM
03/21/17 12:13 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
But they've already announced that from now on it will NOT carry gasoline approvals. That's not in question, the SM/SN rating will be going away on the 5w40 grade. Starting with CK diesel oils, there will be a clear distinction between "high Zn/P" C-only rated oils for diesel engines (and other "off-label" applications where you know what you're doing, such as old flat-tappet V8s) and "Low Zn/P" C- / S-rated oils for modern-era passenger cars and diesels that allow them also. Rotella appears to be tying that distinction to the T6 5w40 being the C-only product, and the new T6 5w30 being the C/S product.
Re: Rotella no longer gas engine rated? [Re: Dave Sherman] #4359393
03/21/17 12:39 PM
03/21/17 12:39 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
This ^,
Re: Rotella no longer gas engine rated? [Re: 440Magnum] #4359395
03/21/17 12:40 PM
03/21/17 12:40 PM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Some documentaton, please.
Re: Rotella no longer gas engine rated? [Re: Dave Sherman] #4359428
03/21/17 01:26 PM
03/21/17 01:26 PM
Kentucky
Ramblejam Offline
Ramblejam  Offline
Kentucky
Hi, Dave.
This is the data sheet you're looking at, correct?
http://rotella.shell.com/products/t6-ful...t6-brochure.pdf
This is for the old CJ-4 product, not the new CK-4 offering.
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359626
03/21/17 05:00 PM
03/21/17 05:00 PM
Phoenix, Arizona - USA
SirTanon Online content
SirTanon  Online Content
So the question on my mind is..
.. Once these CK-4 jugs come out, without the API S(L/M/N) certification on them, the oil should still technically be safe for use in a gasoline engine that does not burn oil, correct?
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 271,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 62,000mi
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359671
03/21/17 05:48 PM
03/21/17 05:48 PM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
This thread and the other one on the same subject should get "merged" IMHO.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (79K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (81K)
>EDGE 0W-20, Fram XG6607
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359689
03/21/17 06:20 PM
03/21/17 06:20 PM
Atlantic Canada
Degreaser Offline
Degreaser  Offline
Atlantic Canada
I am confused, is the new CK-4/FA-4 Shell Rotella oil ok to use in my wet clutch Kawasaki Vulcan 800?
Canada
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359869
03/21/17 09:55 PM
03/21/17 09:55 PM
SACRAMENTO, CA
rrounds Offline
rrounds  Offline
SACRAMENTO, CA
Originally Posted By: 6starprez
If it has JASO MA/MA2 its good for gas engines.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
Re: Rotella no longer gas engine rated? [Re: Atesz792] #4359927
03/21/17 11:18 PM
03/21/17 11:18 PM
BrocLuno Offline
BrocLuno  Offline
^^^ +1
That's all you need to know for motorcycles smile
There are a few diesel bikes out there. But 99.9% are gas, and JASO is about gas engines (and clutches and tranny's, etc.).
Re: Rotella no longer gas engine rated? [Re: 440Magnum] #4359932
03/21/17 11:27 PM
03/21/17 11:27 PM
VA
drseth Offline
drseth  Offline
VA
The rating I am concerned with is the JASO MA rating, which is the motorcycle rating for Japanese bikes. But, after seeing how low the oil rated, I may switch.
Page 1 of 4 1 2 3 4
