I am thinking of using Valvoline Moly-Fortified Multi-Purpose Ford Grease, VV632, for front wheel bearings on a Chevy S10 2WD. I like the sound of having molybdenum for extra protection.
Looking at the datasheet, it is rated NLGI GC-LB, which should make it acceptable. But it differs from the Valvoline GM grease on Timken OK Load and Kinematic Viscosity parameters. Maybe there is a reason they make a separate GM version? But the GM version does not have molybdenum.
Would it work ok?
Would it work ok?
