air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
39 registered members (carlprop, clinebarger, Ag76, Bailes1992, czbrian, 1 invisible), 762 guests, and 64 spiders.
Topics286,440
Posts4,908,215
Members67,622
Most Online2,967
Mar 10th, 2019
Total Quartz Ineo??? #4356805
03/18/17 09:35 AM
03/18/17 09:35 AM
Canada
jackliu Offline OP
jackliu  Offline OP
Canada
Does anyone know anything about this oil if its any good in comparison to BMW Castro and other similar 5W30 synthetics? Also my local shop told me it is LL-01 but on the Total website it says LL-04
Thanks
Re: Total Quartz Ineo??? [Re: jackliu] #4356814
03/18/17 09:44 AM
03/18/17 09:44 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Ineo MC3 is a mid SaPS C3/LL04 .
... and welcome
Re: Total Quartz Ineo??? [Re: jackliu] #4356861
03/18/17 11:03 AM
03/18/17 11:03 AM
5600 feet elevation, Arizona
double vanos Offline
Yes indeed, WELCOME ! Thanks for joining our cozy little asylum......
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Total Quartz Ineo??? [Re: jackliu] #4356909
03/18/17 12:25 PM
03/18/17 12:25 PM
Europe
Ether Offline
Ether  Offline
Europe
It is suitable for both LL specs according to Total,and IMO is a very high quality product.I am using Total Quartz Ineo MC3 5w30 in two Nissan March/Micra cars,along with Total Quartz 9000 5w40,and Quartz 7000 10w40 in Ford cars,a European Escort 1.6.
Re: Total Quartz Ineo??? [Re: jackliu] #4356923
03/18/17 12:51 PM
03/18/17 12:51 PM
Canada
jackliu Offline OP
jackliu  Offline OP
Canada
How about Ineo Long Life? I think thats what my local shop carries, there much difference between MC3 and Long Life?
Re: Total Quartz Ineo??? [Re: jackliu] #4356954
03/18/17 01:43 PM
03/18/17 01:43 PM
Europe
Ether Offline
Ether  Offline
Europe
Ineo Long Life is designed to meet the Euro V Emission VW requirement and is ACEA C3,whereas Ineo MC3 is suited to a wider range of approvals,and is API SN/CF ACEA C3 rated
Re: Total Quartz Ineo??? [Re: Ether] #4357080
03/18/17 06:02 PM
03/18/17 06:02 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Suitable but it can't meet both at the same time, can it? That's impossible isn't it?
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Total Quartz Ineo??? [Re: jackliu] #4357323
03/19/17 05:41 AM
03/19/17 05:41 AM
Europe
Ether Offline
Ether  Offline
Europe
No.I was told that this oil meets the higher LL-04 spec and is backward compatible to LL-01.LL-04 can be used in place of LL-01.
Re: Total Quartz Ineo??? [Re: Ether] #4357326
03/19/17 06:00 AM
03/19/17 06:00 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
LL04 is in no way superior to LL01 unless you have a DPF-equipped diesel car.
LL01 is high SAPS, LL04 is low SAPS.
"Zed's dead baby, Zed's dead."
Re: Total Quartz Ineo??? [Re: rooflessVW] #4357344
03/19/17 07:00 AM
03/19/17 07:00 AM
Europe
Ether Offline
Ether  Offline
Europe
I know that,i am simply relaying the info i received from Total
Re: Total Quartz Ineo??? [Re: Ether] #4357620
03/19/17 12:44 PM
03/19/17 12:44 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
They are making that up then, or don't know what they are talking about. LL-04 is not a "higher" spec than LL-01, not in the sense that it is "better" or more desirable.
And it is not backwards compatible, that is not correct. They are two different specifications, one doesn't supersede the other one.
1994 BMW 530i, 241K
Re: Total Quartz Ineo??? [Re: jackliu] #4358110
03/19/17 10:26 PM
03/19/17 10:26 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
IMHO, BMW LL-04 is suitable for use where LL-01 is recommended ......
whether or not LL 04 is backward compatible or meets/exceeds requirements of LL 01 .. IDK.
Ineo Long Life 5W30 carries VW 50400/50700.
Ineo MC3 5W30 carries VW 50200/505.01 .
Is VW 50400/50700 backward compatible with VW 50200/505.01 ?? I suppose so.
Re: Total Quartz Ineo??? [Re: kschachn] #4358181
03/20/17 01:16 AM
03/20/17 01:16 AM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
Actually LL4 could be stricter specification as it is based upon ACEA C3 spec that is superior to the A3/B4.
Anyway, that's what OEMs and ACEA say. LL04 is not a diesel spec, petrol BMW and MINI cars are specified to use them.
It may be diesel spec in NA but certainly is not in EU. It can be used where LL01 was original recommendation.
02 Nissan Terrano 2.7.TDi Motul 15w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
Re: Total Quartz Ineo??? [Re: jackliu] #4358315
03/20/17 09:03 AM
03/20/17 09:03 AM
Florida
VR6OOM Offline
VR6OOM  Offline
Florida
I've been using total quartz ineo mc3 5w30 for a year now in both my 1.8tsi volkswagens. Over a 10k oci, I DO NOT have to add oil at all. I've gotten great UOA's as well.
2014 VW Jetta Gen 3 EA888 1.8TSI
Total quartz ineo mc3 5w30
Re: Total Quartz Ineo??? [Re: jackliu] #4552791
10/24/17 09:17 AM
10/24/17 09:17 AM
Athens, Greece
unclenontas Offline
unclenontas  Offline
Athens, Greece
What's the difference between the ineo mc3 and ineo ecs? As I saw in Total's "lubadvisor", they now recommendation total quartz ineo ecs 5w-30 for my Peugeot 106.
Peugeot 106 1.1 1999 - Total Quartz Ineo ECS 5W-30
