Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
17 registered members (Char Baby, ctechbob, chrome, Ablebody, deoxy4, AMC, 3 invisible), 765 guests, and 29 spiders.
Topics290,920
Posts4,852,522
Members66,055
Most Online3,590
Jan 24th, 2017
Ford Grease in GM #4351559
03/12/17 05:30 AM
03/12/17 05:30 AM
U.S.
StaleFuel Offline OP
U.S.
I am thinking of using Valvoline Moly-Fortified Multi-Purpose Ford Grease, VV632, for front wheel bearings on a Chevy S10 2WD. I like the sound of having molybdenum for extra protection.
Looking at the datasheet, it is rated NLGI GC-LB, which should make it acceptable. But it differs from the Valvoline GM grease on Timken OK Load and Kinematic Viscosity parameters. Maybe there is a reason they make a separate GM version? But the GM version does not have molybdenum.
Would it work ok?
Re: Ford Grease in GM [Re: StaleFuel] #4351568
03/12/17 06:17 AM
03/12/17 06:17 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
It will work okay, it has a low moly content, just enough to make it black. Personally I wont use a moly grease on any bearing.
For bearings I use Mobil 1 Synthetic and a high moly content grease (3-5%) like Schaeffers 238 on ball joints, tie rods, etc. I was taught that over 40 years ago in school and still go by it, it hasn't let me down yet.
The reason is the skidding moly can cause in some bearings (like roller wheel bearings), the question of what type of bearing and how much moly is acceptable is often debated. I am a simple mechanic and don't want to think about it when greasing a part as you are now so I just keep two guns, one with moly and one without if for no other reason than to make life easier.
The reason I like Mobil 1 red synthetic is only from my experience with it and its water resistance as observed in my snowblower auger. I lubed the auger zerks with it 11 years ago when I bought it and every year since, when a shear pin breaks the auger rotates freely as it should and is as clean as a new pin, totally free from rust and corrosion.
http://www.lubrication.com.au/case-study/bearing-skidding/
Re: Ford Grease in GM [Re: StaleFuel] #4351580
03/12/17 06:55 AM
03/12/17 06:55 AM
U.S.
U.S.
Hmm, this article talks of skidding at low loads. With front wheel bearings there is nearly constant load on the bearings, I think.
So, GM and Ford have different opinions on the moly-induced skidding?
Re: Ford Grease in GM [Re: StaleFuel] #4351591
03/12/17 07:21 AM
03/12/17 07:21 AM
Trav Offline
Trav  Offline
If you google there is more info out there, I just gave you my opinion and what I do. I would say GM and Ford have a different views on moly since one allows it and the other doesn't on the same type of bearing, and since neither manufacture bearings there is real possibility that they come from the same manufacturer.
When I was looking into this I couldn't find any 3% moly greases that were recommended by any company for wheel bearings so I would guess 3% is more than the maximum so whats the acceptable minimum? I don't know and its easier for me just to avoid it for these applications than overthinking it.
Re: Ford Grease in GM [Re: StaleFuel] #4351599
03/12/17 07:47 AM
03/12/17 07:47 AM
U.S.
U.S.
It seems there are different opinions on the moly grease in bearings out there. Although most seem to be against using it.
It would be interesting to see if someone actually had flat spots on their bearing rollers. I have not found any yet. Although I found some vague mention of this in needle bearings on lifters.
I hate to pass up on the benefits of moly without clear evidence. But this is probably the safe route, given the controversy.
Re: Ford Grease in GM [Re: StaleFuel] #4351612
03/12/17 08:06 AM
03/12/17 08:06 AM
NC
BigD1 Offline
BigD1  Offline
NC
I just installed new Timken inner and outer wheel bearings with new races on the front of my Toyota, and I used the Valvoline GM red. It's good stuff. I do have the Valvoline Ford loaded in my grease gun for the suspension parts.
Toyota factory service manual calls for moly on suspension parts, and no moly on the wheel bearings, so that's how I rolled.
1992 Toyota Pickup--Formula Shell 10W-30--Fram PH3614
Re: Ford Grease in GM [Re: StaleFuel] #4351630
03/12/17 08:23 AM
03/12/17 08:23 AM
Trav Offline
Trav  Offline
Is it a real benefit or a contaminate that within a certain limit is acceptable when used in this application? I haven't looked but it could be Ford has had some wheel bearing failures and are using moly as hail Mary pass for.
IMO The fact the manufacturer of the vehicle you own does not specify its use is clear evidence enough for your vehicle.
Re: Ford Grease in GM [Re: StaleFuel] #4351633
03/12/17 08:26 AM
03/12/17 08:26 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
I was also taught in school that bearings didn't get moly grease. Moly (the MoS2 type in grease) is an anti-gallant and generally used for high load, low speed/no speed application.
I also recall that Ford has a 3% moly limit on their grease. Check the content of the Valvoline Ford grease and I would bet that it is no greater than that limit.
And my personal opinion is to not use it on the wheel bearings.
Quaker State across the board.
Re: Ford Grease in GM [Re: StaleFuel] #4351734
03/12/17 10:27 AM
03/12/17 10:27 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I use the valvoline ford moly grease on everything. Never had any issues but that may be my dont know any better luck.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Ford Grease in GM [Re: StaleFuel] #4352160
03/12/17 07:43 PM
03/12/17 07:43 PM
MI
doitmyself Offline
doitmyself  Offline
MI
I asked a similar question here in 2008 to no avail. I have since taken Trav's stance on the subject of Ford's specification to use moly in wheel bearings and try not to induce more gray hair on insignificant matters.
Some faiths refer to these conundrums as "great mysteries" and leave it at that. grin
Re: Ford Grease in GM [Re: StaleFuel] #4357325
03/19/17 05:58 AM
03/19/17 05:58 AM
U.S.
U.S.
It gets more interesting.
The owner's manual for a similar S10 truck states to use
Quote:
wheel bearing lubricant meeting requirements of NLG Grade 2, Category GC or GC-LB
, which the Ford grease meets them. They do not say anything about moly specifically.
But the real kicker is that the Haynes repair manual says to use
Quote:
NLGI No. 2 moly-base wheel bearing grease
Re: Ford Grease in GM [Re: StaleFuel] #4358441
03/20/17 11:33 AM
03/20/17 11:33 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I once used the Valvoline Chrysler grease on my Ford and the wheel fell off..
The "thinking" man's friend.
Re: Ford Grease in GM [Re: Lubener] #4359116
03/21/17 06:03 AM
03/21/17 06:03 AM
Idaho, USA
penguin Offline
penguin  Offline
Idaho, USA
Typical Ford grin
Re: Ford Grease in GM [Re: StaleFuel] #4367027
03/29/17 10:23 PM
03/29/17 10:23 PM
South Eastern, CT
AMC Online content
AMC  Online Content
South Eastern, CT
Stale- Any NGLI# 2, GC-LB rated bearing grease will work for your S-10. The brand or additive type really wont matter as long as the grease is rated for disc brake wheel bearings. The moly won't hurt anything but isn't necessary either.
Last summer, I did a full brake job and re-packed the front wheel bearings on my father's 96 S-10. I used Valvoline synpower which is a moly lithium grease (that is all I had on hand at the time) and everything worked great. The front wheels roll as smooth and precisely as they did when it rolled off the lot in 96.
18 Honda CR-V - Factory Fill
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Delvac 15w-40
Re: Ford Grease in GM [Re: StaleFuel] #4370417
04/02/17 09:05 PM
04/02/17 09:05 PM
Florida
artificialist Offline
Florida
I always used Valvoline Durablend because it said it was for Fords and for everything else. Many conventional based greases would say "For Fords" and others would say "GM, Chrysler, European cars, and Japanese cars." I never had some car have problems because I used that kind of grease in something other than a Ford.
2010 Lancer Ralliart Sportback
