Originally Posted By: sxg6
Where I live, one of the previous owners replaced some older 2 prong outlets with 3 prong outlets, but there is no equipment ground. The wire going to the outlets only has 2 wires.
I've read that surge protectors won't be able to do their job without the equipment ground. Is there any way to protect electronic devices hooked up to these outlets? I know there are whole house surge protectors, and the option to rewire, but I'm hoping there is something easier I can buy or DIY.
The equipment grounding conductor was never a viable path for shunting surge energy to *at the point of use*, MOV (metal oxide varistor) based "protection" was genius pure marketing, not backed up by the actual facts. MOV's were never originally designed to be used in such a manner to begin with. The only place that surge energy can be diverted to ground is at the service entrance panel, for the express reason of impedance. Surge energy is high frequency, especially surges induced from nearby (not direct, we're not talking about direct strikes here) lightning strikes, where most of that energy is around 1 Mhz.
What this means is that the principal factor of impedance in relation to surge/spike enrgy is conductor length, as opposed to conductor size. The distance from your grounding electrode conductor to your grounding electrodes off your your panel is far shorter than the distance of the knob-and tube, Romex, etc is from your panel to your wall outlet. For this very reason, the National Electrical Code states that conductor leads from a surge protection device at the service entrance are to be as short as possible (leads longer than 6" start to defeat the purpose of the panel mounted protector).
Only about 15% of surge events originate from outside of a building, the main source of them is internal switching on and off of motors, like furnace fans, refrigerator, air conditioners. High frequency noise is also significantly impressed back onto all of your house wiring from non-linear loads, all those wall-wart SMPS (switch mode power supplies) that digital electronics inherently does via rectification of AC to DC. This high frequency noise is damaging by itself, degrading electronics over time, and making it more susceptible to higher energy spikes when they do occur.
Any surge energy that would make it to your wall outlet on the phase conductor (hot) is going to ignore being "shunted to ground" all the way back tens of feet supposedly to your ground rods, and water pipe if you are using that as one of your grounding electrode conductors. Instead it will see all those signal grounds of your data cables, HDMI, Coax, RCA, headphone jacks, USB, because those are part of the grounding electrode conductor at the wall outlet when you have this 3rd wire (required for *new installations* many decades now yes, but this is for safety only, not for protection of electronics, also not everyone has around $20,000.00 in cash laying around to pay an electrical contractor to rip all your old wiring out and put new romex in)).
Surge energy sees those as parallel paths. Remember electricity does not expressly "follow the path of least resistance", rather it takes *all* available paths including the path of least resistance. This means that your typical big box store suppressor is actually doing the complete opposite of what you want to do. It will cause damage by sending that surge energy right back into your connected equipment, as oppose to the physical Earth.
There is really only one way to protect equipment at the wall outlet, and that is to use a series-mode device that does not shunt energy to the EGC. You can read about how this technology works below. Note these units are far more expensive than what most people might be willing to spend, but they do in fact work, I have used them for 16 years, I have 5 units using such technology. Surgex is even better than Zerosurge because they have additional EMI/RFI filtering that is patented. These units are so robust that they are still great investments even when bought in the used market, where you can get them much cheaper than retail.
https://zerosurge.com/pq-filter/
http://espsurgex.com/surgex/
