F1 - 2018 Russian Grand Prix
by gofast182. 09/26/18 06:11 AM
Pets Puking in Middle of the Night :~/
by LoneRanger. 09/26/18 05:16 AM
Is there a new (2018) list of GM Dexron VI licensees?
by garageman402. 09/26/18 01:20 AM
Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
Everzooom, donnyw, Dfeeds, JJ_RA, Captjayd
66077 Registered Users
85 registered members (andyd, 853okg, Audios, BAJA_05, Bandito440, 65convertible, 11 invisible), 1,264 guests, and 36 spiders.
Topics291,028
Posts4,854,841
Members66,077
Most Online3,590
Jan 24th, 2017
Page 1 of 5 1 2 5
I Think I Killed It #4345960
03/05/17 09:53 AM
03/05/17 09:53 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
I don't normally like to go above 80, because the car is over 30 years old and the 3 cylinder engine is probably more fragile than most, but I was getting tailgated on the expressway this evening and allowed my speed to creep up around 100. Burning smells ensued (not necessarily from the car, Taiwan has a lot of burning smells) so I got off the expressway and took slower roads home.
Car started making exhaust-blowing noises, which I attributed to a blown exhaust. I'd noticed it had got a lot rustier earlier that day. Stopped but couldn't see a leak in the dark without a torch. Noise got worse. Close to home, seemed to loose a bit of power, so maybe not just a blowing exhaust.
Back home, with torch, still can't see an exhaust leak, but note there is no coolant in the reservoir.
That's head gasket, and/or warped head, isn't it?
Re: I Think I Killed It [Re: Ducked] #4345962
03/05/17 09:55 AM
03/05/17 09:55 AM
ME
eljefino Offline
eljefino  Offline
ME
Do you have a catalytic converter? Maybe it's plugged?
Maybe the coolant was gone before yesterday. Red herring.
Re: I Think I Killed It [Re: Ducked] #4345963
03/05/17 09:57 AM
03/05/17 09:57 AM
down in the park
Jetronic Offline
Jetronic  Offline
down in the park
shouldn't be if you never hadexcessively high temps.
any oil weeps that might have gotten hotter than usual?
see if there's air/exhaust going to the header tank with the engine running.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus Prime 2 215/50R17 (front)
Pirelli P7 Cinturato 225/45R17 (rear)
Re: I Think I Killed It [Re: Ducked] #4345966
03/05/17 10:00 AM
03/05/17 10:00 AM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
I'd put some coolant back in and see how fast it goes down. If you goes through the coolant with no visible leak , probably is a head gasket. You did have it reved up. I'd also check the radiator cap in case its not holding pressure.
What kind of coolant are you running? 30 year old head gaskets might not like some of the newer coolants, and can degrade.
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: I Think I Killed It [Re: eljefino] #4345967
03/05/17 10:01 AM
03/05/17 10:01 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
No, I don't. Wouldn't have though that'd make a blowing noise, but I have no experience of catalytic converters, and don't much want any.
Coolant was at the full line this morning, before setting off, but I didn't check it during the day and didn't notice its level when I first looked for the exhaust blowing.
No sign of coolant on dipstick.
Re: I Think I Killed It [Re: Ducked] #4345973
03/05/17 10:10 AM
03/05/17 10:10 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Take a gun and shoot it. Not worth the $$$$ to repair. !00 mph in a three cylinder vehicle? I don't think so. crazy
Re: I Think I Killed It [Re: Yah-Tah-Hey] #4345981
03/05/17 10:23 AM
03/05/17 10:23 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
new Mirage estimated at 125 mph top speed
There must be lots of liars out there because I had no problem finding many 3 cyl owners who claimed they took a measured mile run in their 3 cyl and were in the 100-110 mph range at top speed.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: I Think I Killed It [Re: Yah-Tah-Hey] #4345986
03/05/17 10:28 AM
03/05/17 10:28 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
I don't think so either, but then, I don't think we're still in Kansas, Toto.
The rest of the world uses kilometers.
Re: I Think I Killed It [Re: Ducked] #4345991
03/05/17 10:33 AM
03/05/17 10:33 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
In your place, I would check and refill the coolant (and all other fluids) and take it for a test drive at "normal" speeds. See if it drives as usual or if it starts to use coolant again. You could also drain some oil out (or do a full change) to see if it has water/coolant in it.
Thick vs Thin test: 15k / 43k miles complete
Re: I Think I Killed It [Re: Ducked] #4345993
03/05/17 10:34 AM
03/05/17 10:34 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I was wondering about the units on the 80 and 100 numbers...
Re: I Think I Killed It [Re: spasm3] #4345994
03/05/17 10:35 AM
03/05/17 10:35 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
Don't know. It's green, with Chinese writing on the jug.
I'd get it translated but it probably doesn't say anything meaningful anyway. I'd doubt its anything very exotic, though, since it was a supermarket own-brand and not very expensive.
Re: I Think I Killed It [Re: Ducked] #4345995
03/05/17 10:35 AM
03/05/17 10:35 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You may have lost a head gasket, as someone said fill the system and do a leak check. A HG is easy on this engine.
Skoda Fabia 1.0 will do 100 Mph the 1.2 can hit 120 Mph and both are 3 cylinders.
Re: I Think I Killed It [Re: Ducked] #4345999
03/05/17 10:41 AM
03/05/17 10:41 AM
USA
mk378 Offline
mk378  Offline
USA
Wait for daylight. Refill the cooling system. Look for external leaks. Start engine and confirm it is running on all cylinders. When you start it with the radiator cap off, a blown head gasket will have bubbling and coolant blowing out of the radiator even when the engine is cold. This is generally the first symptom of a small leak, it may happen even without getting coolant in the oil or steam from the tailpipe.
Re: I Think I Killed It [Re: Ducked] #4346018
03/05/17 10:55 AM
03/05/17 10:55 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Folks, the OP is in Taiwan, 80 ='s 50 MPH.
Me: 13' VW GTI 3 door 6 speed manual
Re: I Think I Killed It [Re: Ducked] #4346020
03/05/17 10:56 AM
03/05/17 10:56 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
In other country, people are not as fast throwing away cars as it is in the US.
If it is a 3 cylinder car, it is probably small and easier to work with.
I am sure there are people with resources in Taiwan that can fix the car economically.
30 years old does not matter.
What kind of car is it? may be check in the forum that discuss your car and see if it worth fixing.
  • 2017 Toyota Sienna
Page 1 of 5 1 2 5
