Washing coolant down a storm drain?
by jharrison - 02/22/20 12:57 AM
storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
34 registered members (2013ecof150, BBDartCA, 750IX, aquariuscsm, bhmax, Aero540T, 2 invisible), 1,211 guests, and 18 spiders.
Topics301,769
Posts5,202,397
Members70,775
Engine oil additives little changed during OCI #4343296 03/01/17 08:48 PM
L
ledslinger Offline OP
L
Which additives levels change little during an OCI?
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4343300 03/01/17 08:54 PM
O
Ohle_Manezzini Offline
O
Are you willing to add the highly changeables to keep the oil useable?
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4343311 03/01/17 09:05 PM
CT8 Offline
The additive change little by measurement but they can be depleted.
2015 F150 2.7
2018 F350 6.2
Re: Engine oil additives little changed during OCI [Re: CT8] #4343320 03/01/17 09:12 PM
L
Linctex Offline
L
Do you mean (for example) that Zinc (ZDDP) and Moly numbers remain high, but "insolubles" get so high that they negate the remaining additives?
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4343343 03/01/17 09:34 PM
CT8 Offline
The calcium for example will still to spec but it wont buffer any more.Looking at the UOAs the additive PPM numbers seem not to change
2015 F150 2.7
2018 F350 6.2
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4343352 03/01/17 09:45 PM
Donald Offline
For big diesel engine they publish guides as to when to change. Iron, soot, fuel dillution, and TBN. When one of them gets too high or low its time to change the oil. The ppm of additives is not really directly considered.
2015 Ford F-250 w/Powerstroke
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4343456 03/02/17 04:02 AM
W
weasley Offline
W
You may see additive elements (Zn, P, Ca, Mg etc) actually increase over time due to concentration by volatility - as the lighter base oil fractions evaporate they leave behind the additives.
Some of the detergent elements can be caught in the filter - for example CaCO3 (the 'B' in TBN) reacts with sulfuric acid (from combustion of sulfur-containing fuel) and a bit of water to become CaSO4, aka plaster of Paris - this oil-insoluble salt then gathers in the filter, hence removing Ca from the oil. It's a small effect though and may not be noticeable, especially with the volatility effect described above.
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4343640 03/02/17 11:00 AM
MolaKule Offline
Global Moderator
Global Moderator
If an additive component contains say an initial 80 ppm of MoDTC, where would the xtra moly come from even if some of the lighter base oil fractions were to evaporate?
I'm a Student Pilot. Frightening, isn't it?
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4343659 03/02/17 11:19 AM
K
kschachn Offline
K
How are "additive levels" being measured?
An ICP analysis will show the same elements regardless of the ability of any additive to be chemically effective.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Engine oil additives little changed during OCI [Re: MolaKule] #4343774 03/02/17 02:54 PM
M
MotoTribologist Offline
M
The overall concentration would increase as the diluent (base oil) was lost. If you have 80 ppm MoDTC in a sump containing 5000 grams of oil and say it were 15% volatile. The loss of that 15% would leave you with 4250 grams of oil. With a concentration of 80 ppm, you would have had 4 grams of MoDTC in the original volume. That same 4 grams of MoDTC now in 4250 grams of oil would result in a concentration of 94 ppm.
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4344170 03/02/17 10:00 PM
MolaKule Offline
Global Moderator
Global Moderator
You're assuming a fraction of the 80 ppm MoDTC will not leave with the 15% volume of the oil that was lost.
I don't think conservation of mass supports your theory.
Re: Engine oil additives little changed during OCI [Re: MotoTribologist] #4344258 03/03/17 12:57 AM
SonofJoe Offline
You're absolutely 100% correct. I used to see this all the time on the Sequence IIIG and Peugeot TU5, especially on high Noack oils. It used to amaze me how many of my fellow formulators could not get their heads around something that to me was so blinding obvious.
Re: Engine oil additives little changed during OCI [Re: SonofJoe] #4344521 03/03/17 11:46 AM
V
Virtus_Probi Offline
V
Seems just like harvesting salt by letting seawater evaporate...
2014 Forester XT, 111000 miles
Last Change;
M1 0W30 AFE
Tokyo Roki 15208AA170 filter
Re: Engine oil additives little changed during OCI [Re: MolaKule] #4344631 03/03/17 02:22 PM
M
M
You are 100% correct in the assumptions made but it was just mena to be a simple answer to your question.
I've never thought about this topic before this time though. Vaporization of the base fluid would likely carry away some of the MoDTC solubilized within as you say. However isn't it also likely that as the oil vaporizes it's decreased density would force a lower concentration of additives in that portion than the liquid portion no?
Maybe I am just thinking myself into circles but that makes sense to me sans any evidence or actual research.
Edit: Plus, conservation of mass assumes a closed system (even if that system is the entire universe in most cases). This question is in regards to the engine oil as the system and it being open to the environment so there can certainly be net changes in mass.
Re: Engine oil additives little changed during OCI [Re: ledslinger] #4344645 03/03/17 02:34 PM
K
kschachn Offline
K
Distillation can be unpredictable. Any non-volatile components in the mixture will not appear in the distillate but anything that has a similar boiling point to the hydrocarbon fractions of the oil will carry over. Are the additives liquids or are they solid compounds dissolved in a hydrocarbon carrier? I don't know enough about formulated motor oils to answer that.
Plus it isn't a closed system for more reason than one.
1994 BMW 530i, 251K
