storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
36 registered members (Cdn17Sport6MT, carlprop, cb4017, Blkstanger, c502cid, blufeb95, 2 invisible), 1,368 guests, and 18 spiders.
Topics301,768
Posts5,202,390
Members70,775
Determining Viscosity #4341288 02/27/17 03:02 PM
MolaKule Offline OP
Global Moderator
Global Moderator
This exercise is a bit more involved and requires a Scientific Calculator and is open to all.
One way of measuring viscosity is to use a "Rotating Concentric Cylinder" viscosimeter, sometimes called a, "Couette" viscosimeter.
A rotating cylinder (the Inner Cylinder), is placed inside another (outer) cylinder and the fluid whose viscosity is to be measured in poured into the gap, g.
The Inner Cylinder is rotated at a specific RPM and the amount of Torque to rotate the Inner Cylinder is measured.
Note: * is multiplication and X^n is a number raised to the "nth" power since we don't have an equation editor in BITOG.
The viscosity is given by: u = T*g/(4*pi^2*R^3*n*L) = Absolute Viscosity in SI units of N.s/m^2
T is torque, measured at 1.8 N.m,
g is gap between Inner and Outer Cylinder, or 0.15 cm,
Outer Diameter of Inner Cylinder is 12 cm,
L is length of each each cylinder which is 40 cm long,
n is RPM, 300 RPM
R is Radius of Inner Cylinder.
Hints: Use 39.48 for 4*pi^2; Convert all given units to meters and seconds; answer will be in N.s/m^2.
We will disregard any "end" effects.
The result will be a 30 Grade motor oil at ~ 40C.
Re: Determining Viscosity [Re: MolaKule] #4341488 02/27/17 07:10 PM
O
Ohle_Manezzini Offline
O
66.83 mm square per second.
Re: Determining Viscosity [Re: MolaKule] #4342055 02/28/17 11:20 AM
MolaKule Offline OP
Global Moderator
Global Moderator
I'm a Student Pilot. Frightening, isn't it?
Re: Determining Viscosity [Re: MolaKule] #4342247 02/28/17 03:41 PM
G
Garak Offline
G
Showing units:
1.8 N.m 0.0015 m / [4 pi^2 (0.06m)^3 5 rev/s 0.4m] = 0.158314349 N.s/m^2 = 0.2 N.S/m^2, given one significant figure. wink
Calculating through the units does indeed show the units you asked for are obtained.
Plain, simple Garak.
Re: Determining Viscosity [Re: MolaKule] #4342256 02/28/17 03:51 PM
O
O
Force?
Newton * second / square meters
Re: Determining Viscosity [Re: Ohle_Manezzini] #4342306 02/28/17 04:50 PM
G
Garak Offline
G
Newtons are the force, this expression is a dynamic viscosity, where 1 N.s/m^2 = 10 P or 1000 cP.
Re: Determining Viscosity [Re: Ohle_Manezzini] #4342399 02/28/17 06:47 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Originally Posted By: Ohle_Manezzini
Force?
Excellent Garak. happy
RPO, had I given you the density you could have determined the Kinematic Viscosity in the SI units of m^2/s or cgs units of centistokes or cSt, with proper conversion coefficients.
Re: Determining Viscosity [Re: MolaKule] #4342645 02/28/17 10:34 PM
O
O
So the answer can also be expressed as 200 cP at 40C...
Or:
In cst is 200
In Poise is 2
In stokes is 2
In SSU is 927
RPO
Re: Determining Viscosity [Re: MolaKule] #4342695 02/28/17 11:14 PM
G
Garak Offline
G
Originally Posted By: MolaKule
Excellent Garak.
Thanks. Technically, I shouldn't have put rev/s as a unit in my equation, since revs really aren't a unit. To be rigorous, I should have just used the unit of s^-1. wink
Re: Determining Viscosity [Re: MolaKule] #4342742 03/01/17 05:16 AM
G
Garak Offline
G
There, Mola. I made it look pretty, albeit a bit larger than I intended.
Re: Determining Viscosity [Re: MolaKule] #4342794 03/01/17 07:29 AM
O
O
And the range for a 30 weight oil @ 40C is: 55cP to 82cP!
So, this oil isn't a 30 grade at all
Sorry Mola, could't resist, just grabbed a coffee wink
Cqd,,
RPO
Re: Determining Viscosity [Re: Ohle_Manezzini] #4343087 03/01/17 03:36 PM
MolaKule Offline OP
Global Moderator
Global Moderator
Cqd,,
RPO
RPO, you need more than coffee. grin2
Look at F.M. White's, Fluid Mechanics, McGraw-Hill, 2003.
He has a chart of various fluids (Viscosity vs. Temperature) expressed in Absolute Viscosity or N.s/m^2, and the SAE 30 oil [email protected] does indeed pass through the answer given by Garak.
Re: Determining Viscosity [Re: MolaKule] #4343277 03/01/17 08:22 PM
O
O
Ah, 20C, Ok, grin
Re: Determining Viscosity [Re: MolaKule] #4343742 03/02/17 01:57 PM
MolaKule Offline OP
Global Moderator
Global Moderator
A viscosity curve will pass through various values of Absolute Viscosity verses temperature.
For Garak's round-up value of 0.2, the curve is right on at 20C.
At 0.1583 N.s/m^2, the curve passes through 26C because of it's slope.
I accepted any numerical value between 0.158 N.s/m^2 and 0.2 N.s/m^2.
