Nick1994
$100 site donor 2024
This is for my dad's 2007 Toyota FJ Cruiser 4x4 with the 6-speed manual transmission. It's a full time 4x4 and has around 115k miles. Has the factory electronic rear locker.
It's got all original fluids in it except the engine oil, and I mean everything is original. Time for a fluid change!
Below here I've got all the fluid specs from the Owner's Manual. Need some help with differential oils. This is AZ so no worries about being below 0 degrees. It specs SAE90 gear oil for temps above 0 and 75w90 for cold temps, but can 75w90 be used year round? Any recommendations?
Thanks for the help guys.
Transmission:
1.9qts GL4 or GL5 75w90
Transfercase:
1.5qts Hypoid GL5 75w90
Front Diff:
1.5qts Hypoid GL5 SAE90
Rear Diff:
3.1qts Hypoid GL5 SAE90
Differential Fluid Specs:
Recommended oil viscosity: Front
Full−time four−wheel drive models Above −18_C (0_F)
SAE 90 Below −18_C (0_F)
SAE 80W or 80W−90
Rear
Above −18_C (0_F)
SAE 80W or 80W−90
Transmission:
Transfercase:
Front Diff:
Rear Diff:
SAE 80W or 80W−90
Rear
Above −18_C (0_F)
SAE 80W or 80W−90
