2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
115 registered members (69GTX, 2015Corolla, 92saturnsl2, 2004tdigls, 10 invisible), 1,824 guests, and 35 spiders.
Topics290,911
Posts4,852,340
Members66,055
Most Online3,590
Jan 24th, 2017
2014 Taurus #4340373
02/26/17 01:43 PM
02/26/17 01:43 PM
Minnesoder
crookedaxle Offline OP
Minnesoder
What is the best 5w-20 full synthetic to run in my wife's new car? What to use for oil change intervals?
Re: 2014 Taurus [Re: crookedaxle] #4340377
02/26/17 01:49 PM
02/26/17 01:49 PM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Does the car spec full synthetic? I was under the impression Ford specs their Motorcraft Semi-synth for it.
That said, if you must use full synthetic, really any full synth on the shelf at WalMart should do the trick quite well. Quaker State, Valvoline, Pennzoil, Castrol.. They all are pretty darn good.
As far as the Oil Change Interval, I believe those cars have an IOLM.. just follow that.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 262,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 57,000mi
Re: 2014 Taurus [Re: crookedaxle] #4340391
02/26/17 02:10 PM
02/26/17 02:10 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
SirTanon is right, but to help better do you plan to extend beyond the OLM or just go with the OLM recommendation? Plenty of extended drain oils out there for you if you do, M1 EP, QSUD, Amsoil.
Thick vs Thin test: 15k / 43k miles complete
Re: 2014 Taurus [Re: crookedaxle] #4340416
02/26/17 02:42 PM
02/26/17 02:42 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Please define what best means? Oil is pretty much oil from quality blenders.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2014 Taurus [Re: crookedaxle] #4340420
02/26/17 02:47 PM
02/26/17 02:47 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Good question and I'm glad you asked because I was going to start a new thread on this. Here is a link for you to read:
http://www.bestproducts.com/cars/parts/g1286/car-motor-oil/
Re: 2014 Taurus [Re: crookedaxle] #4340421
02/26/17 02:48 PM
02/26/17 02:48 PM
Zimbabwe
horse123 Offline
horse123  Offline
Zimbabwe
Castrol Magnatec, no question.
Not saying you can go wrong with anything else, but I've never seen any other oil have such consistently amazing UOAs
Re: 2014 Taurus [Re: crookedaxle] #4340439
02/26/17 03:15 PM
02/26/17 03:15 PM
FL, USA
gregk24 Online content
gregk24  Online Content
FL, USA
Todays synthetics are available for such a great price at WM, I see no reason not to run them. So I would use any of the "big four" (PP, M1, VSP, Edge) with confidence.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: 2014 Taurus [Re: horse123] #4340550
02/26/17 06:29 PM
02/26/17 06:29 PM
Minnesoder
Minnesoder
Better than Castrol Edge Extended Performance?
Re: 2014 Taurus [Re: crookedaxle] #4340552
02/26/17 06:31 PM
02/26/17 06:31 PM
Minnesoder
Minnesoder
This is the car we bought to replace a 2012 Chevrolet Traverse with the dreaded cam chain fiasco. I will only run full synthetic in an engine like this from now on. 7,500 miles max regardless of the OLM.
Re: 2014 Taurus [Re: crookedaxle] #4340553
02/26/17 06:33 PM
02/26/17 06:33 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
It seems to get better UOA results from what I've seen. Maybe owners push the Edge too far while owners who use Magnatec change at a more reasonable interval.
Re: 2014 Taurus [Re: crookedaxle] #4340665
02/26/17 08:41 PM
02/26/17 08:41 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Personal preference I usually go M1 EP, pennzoil ultra platinum, M1, Pennzoil platinum, and valvoline as last resort.
Re: 2014 Taurus [Re: crookedaxle] #4342216
02/28/17 03:51 PM
02/28/17 03:51 PM
Houston, TX
GenaFishbeck Offline
Houston, TX
Hi @crookedaxle - For premium performance, we recommend Pennzoil Ultra Platinum 5W-20. This full synthetic oil keeps pistons up to 65% cleaner than the toughest industry standards and provides unsurpassed wear protection. Hope this helps!
- The Pennzoil Team
Re: 2014 Taurus [Re: crookedaxle] #4342218
02/28/17 03:59 PM
02/28/17 03:59 PM
Balearic Islands , Spain
FordCapriDriver Offline
Mobil 1, Pennzoil platinum will give you equally good results.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort Mk4 Xr3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: 2014 Taurus [Re: CT8] #4342219
02/28/17 04:00 PM
02/28/17 04:00 PM
Texas
4WD Offline
4WD  Offline
Texas
Best comes after Good and Better at Discount Tire.
Re: 2014 Taurus [Re: GenaFishbeck] #4342580
02/28/17 10:09 PM
02/28/17 10:09 PM
Virginia
bbhero Online content
bbhero  Online Content
Virginia
And where to buy this great oil?? No where but maybe Pep Boys. Or online somehow. It is no where to be found in Wally World, AAP, AZ, O Reilly's, Carquest etc... And some people don't want to buy things online.
I do like Pennzoil Ultra Platinum a lot. If I could only find it somewhere near me.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
