Its time to change the oil in my summer ride again. It's equipped with a Chevrolet 6.0l LS engine. Aftermarket cam, heads, valvetrain, stock bearings and bottom end. This summer the car will see several thousand miles of highway cruising, several hours of sustained high RPM on a road course, and several dozen drag strip passes. I don't have an oil cooler, But I try to keep it under 250*F.
What oil would guys recommend? Trying to stay under $10/qt. Car doesn't have cats, so I'm not restricted as to what formulation I can run. Needs to be available in a 10w30 or 5w30.
