Most of the GDI intake valve deposits are a result of oil seeping past valve seals and the balance from the PCV/vacuum system. Some engines like the earlier Audi V8s had huge issues resulting in significant performance loss and even class action law suites. BMWs are also prone but to a much lesser degree. Fuel additives do nothing, repeat, nothing for the intake valves because the fuel does not contact the back of the intake valves like a port injected engine. Mechanical cleaning is the only way to remove the deposits effectively. These intake sprays may help a tiny bit but they may do more harm than good. Low SAPs oil and oils with low volatility will help a bit. A baffled catch can on the PCV system will help a bit. The amount it helps will depend on how bad the stock PCV system is. Nothing can eliminate the valve seal seepage and it gets worse with age, other than replacing them in an older engine. Toyota/Lexus got it right with both port and GDI but this is obviously a more expensive and complicated set up that most mfgs would avoid.
