Originally Posted By: leeaspell
So have read a lot about issues with the 6F35 transmission which my fusion has. Currently has 50k km on it, no issues or hard shifts or anything, but I'm thinking about doing a drain and fill at each oil change, which would be once a year, only put about 10k a year on, mostly the wife short tripping to work everyday.
Is it worth it, or just run it. She works for Ford so u can get mercon lv at a sort of cheaper price, or I can get motomaster for $30 a gallon.
Secondly, is it possible to add a dipstick to these units? Hate not being able to physically check it
This is MASSIVE overkill. Yes, the 6F35 is hard on fluid, but doing the drain&fill every 10k is really not necessary. Based on my personal experience, I'd say do it once every 2 years - 20,000 miles apart - and just drain the fluid once, and refill once. Standard time frame is every 30,000 miles, but I'd say given your use and OCI timeframe, that 20,000 is a good number. You'll also stay ahead of the game.
FYI - I own a 2010 Fusion with the 6F35 trans and a 2.5 liter, which just passed 226,000 miles this week.. and I'm still on the original trans. My last drain&fill was done at approximately 24,000 miles. I was going to do 30,000 miles, but I was doing an oil change at the time, and the fluid was getting dark so I decided to pull the trigger. I do just a single drain&refill of ~1gal each time, vs. doing one, driving for a bit, then doing a 2nd. Going forward, I will most likely keep on a 25,000 mile schedule just to be safe, depending on how dark the fluid gets in that time.
Originally Posted By: gregk24
I didn't realize the 2013 had transmission issues, I thought it was only the previous generation that did...unless they share the same transmission?
The 6F35 trans from the 1st gen was carried over into the 2nd gen, but is not paired with all of the engines. I believe it also received new programming at some point.
