Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
83 registered members (830Lee, 97prizm, ABN_CBT_ENGR, 4WD, 55hambone, 555, 6 invisible), 2,066 guests, and 32 spiders.
Topics306,053
Posts5,286,514
Members71,593
Spark plug for GCV160 Honda engine. #4330211 02/15/17 03:37 PM
2
2civics Offline OP
2
I have a conundrum. The spark plug that came with the mower is a NKG BPR5ES. The manual calls for a NKG BPR6ES. I need to replace this spark plug. Which one do I go with? Thanks.
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4330224 02/15/17 03:45 PM
G
GravelRoad Offline
G
My parts lookup calls for a BPR6ES if that helps.
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4330237 02/15/17 03:54 PM
H
HerrStig Offline
H
My Honda mower came with the BPR6ES. THe 5 is the next hotter heat range. The "R" indicates a resistor plug, not sure why a mower
needs that. I use a BPR6EV which is the platinum tip version of the BPR6ES plug. A little more expensive but the fine wire tip works well. I've seem that plug in eveything from BMW bikes to SAAB auto engines.
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4330255 02/15/17 04:10 PM
2
2civics Offline OP
2
Okay. Must have been their mistake from the factory. Thanks!
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4330373 02/15/17 06:00 PM
T
Trav Offline
T
Look at the color of the plug, if its good use that heat range if its looks looks white drop the heat range (not applicable to FI engines). You can use either BPR6EIX or BPR5EIX if you want to run a long life easy starting iridium.
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4330574 02/15/17 09:36 PM
T
TLAR640 Offline
T
Per Honda's website, mowers come with BPR5ES, and pressure washers have the BPR6ES.
I emphatically agree on BPR5E-IX iridium plugs making for easy starting.
16 Colorado, 09 CTS, 15 KTM, 17 Ducati
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4330590 02/15/17 09:58 PM
E
EdwardC Offline
E
I've used the V-Power version, BPR5EY in small Honda engines with no trouble. I've never spring for an iridium since most of my small engine es really so they much use. As long as I use NGKs, no trouble starting!
I recently bought a used EU2000i with a super cruddy original NGK spark plug, still ran just fine. Either the plug or the coil were awesome.
Re: Spark plug for GCV160 Honda engine. [Re: TLAR640] #4330954 02/16/17 10:20 AM
R
Rab6715 Offline
R
+1. 5 for mowers, 6 for washers. I think all the Chonda stuff is 6, unless you use the Torch OEM Chinese plug.
Re: Spark plug for GCV160 Honda engine. [Re: Rab6715] #4331016 02/16/17 11:21 AM
J
jeepman3071 Offline
J
I hate those stupid Torch Chinese plugs. They have caused some strange running issues on Predator engines. Now whenever I build a Predator for a minibike/go kart or install one as a replacement on equipment I throw away the Torch garbage and replace it with an NGK. No issues since then. thumbsup
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4331393 02/16/17 07:44 PM
E
Eddie Online Sleepy
Online Sleepy
E
A resister limits the amount of current but, not the voltage so the plug last longer. In addition, the lack of EMF on your neighbors TV & radio is appreciated.
2014 CX5 Touring 2.5L :-)
Re: Spark plug for GCV160 Honda engine. [Re: jeepman3071] #4331453 02/16/17 09:03 PM
W
Whimsey Offline
W
I thought the same about the Torch spark plugs until I bought a Troy-Bilt snow blower with a Chinese PowerMore engine. Before it's first use I bought a NGK replacement plug. But I decided to see how "bad" it ran with the Torch plug. After about 17 hours of hard use the snow blower still ran like a champ with the Torch plug ???. I guess the quality level at manufacturing can vary greatly. Would I buy a Torch replacement plug, NO! In addition to strongly being iffy they cost 3X the price of a NGK plug shocked2.
Whimsey
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4446402 07/01/17 12:47 AM
N
NSG Offline
N
I am sorta having the same issue on spark plugs.
I will be acquiring my dad's Husqvarna 7021R which uses a Honda GCV160 mower.
The instruction manual that I am looking at on Husqvarna's website specifically for the lawnmower states:
Spark Plug: NGK BPR6ES (Gap: .030")
But then Honda's manual states otherwise...
Stuff like this really annoys me. I ordered the BPR6ES spark plug so will that mess anything up? I will have to have my dad look but I'm almost positive that's what is in the mower now, and has been for 9 years...lol
Thanks,
-Nigel
~NSG~
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4446515 07/01/17 08:02 AM
tom slick Offline
It won't mess anything up, the "6" means it's a little cooler than the "5".
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4447224 07/02/17 08:09 AM
E
exranger06 Offline
E
I have the BPR6ES in my mower. As far as i know that's what came in it from the factory.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Spark plug for GCV160 Honda engine. [Re: 2civics] #4454050 07/09/17 07:34 AM
A
Audioquest Offline
A
My Toro mower has a GCV160 engine and it came with a BPR6ES and that is the recommended plug in the manual.
2011 Toyota RAV4 AWD 2.5
2019 Nissan Rogue SV-Tech AWD
1991 Honda CRX Si
