IMHO: Picking which oil to use for your specific car/truck is more nuanced than just picking a grade and brand. And sometimes this is a PITA!
For example, Kia (for my car) recently released a TSB (#076) that attempts to clarify their recommendations for their 2.0T turbo engine. This is due to many oil issues (primarily sludging) their owners have experienced. What results (rod knock) is a whole other thread!
So Kia says the following in their TSB:
"Recommendation:
-ACEA A5 or above/5W-30
Allowed Oil Grade
-API SL, SM or above
-ILSAC GHF-3, GF-4 or above
-ACEA A3, A5 or above
Allowed SAE Viscosity
5W-30/5W-40
* Notice
For best performance and maximum protection during all types of operation, select only those lubricants which:
1. Satisfy the requirements for API, ILSAC or ACEA classification.
2. Have proper SAE grade number for expected ambient temperature range.
2. Lubricants with neither SAE grade number, API, ILSAC and ACEA service classifications on the container should not be used."
So when I look at what oil I should run, I'm going to stick as close to those specifics (as many as possible is better) that I can for my GDI Turbo engine. That is my opinion in understanding Kia's requirements and knowing I have a nice 10YR/100K mile power-train warranty (upgraded in 2016 to 120K on the short block) I'd like to keep.
Based on this, I would NEVER run Rotella T6 5W-40 in my engine! It is a fine oil for the right application, which clearly is aimed at diesel applications as the primary user.
So what have I done?
Historically, I've run M1 0W-40 Euro oil (since new) which is API SN, ACEA A3/B4 rated oil but does NOT meet ILSAC GF-4 or above. It has been a compromise. Since I don't "have" to meet LL-01, I think the newer "FS" version would still be fine by the numbers. The UOA's may indicate otherwise.
On the other hand, Castrol Edge (GC or BC) 0W-40 Euro oil (by these requirements for my car) is a better oil for me to use as it is API SN, ACEA A3/B4 AND is ILSAC GF-3,4,5 rated. The fact that it has Ti as a marketing claim of better wear resistance is a potential plus (to be bore out by results as best we can know them).
Rotella T6 5W-40 on the other hand is ONLY API SM rated (according to their T6 PDF file in their website) in my application and does not meet the ACEA or ILSAC requirements I need. So it is a "non-starter" for me. However, that might not be an issue for other people's cars and I think I was being too pig-headed about it. Sorry dudes.
Guys, I'm not attempting to start a "flame war" and I'm sure attempting to learn as much on the subject as I can but this is where I'm at on the subject for MY CAR. YMMV.
