Originally Posted By: AZjeff
Water Wetter is a surfactant, in theory it should promote a better liquid/metal interface. We ran it in a circle track stock car running 100% water and a flow restrictor instead of a thermostat and it did lower max running temp. Not sure how it can be measured in a car with a thermostat as it would just stay closed until it reaches temp. Maybe under heavy load conditions it would slow the temp rise and/or lower max temp.
How did it impact the maximum metal temperature or the cylinder block and head? That's what is really important not necessarily the coolant temp.
No idea, we're talking a bunch of Pa rednecks running a 1/2 mile pavement stock car not Petty Enterprises here. All I know is the driver reported lower gauge temps with it so we used it. I wouldn't call a Redline product snake oil but it may not apply to all uses.
Think logically...your pump moved an amount of water between the radiator and the engine, exchanging heat between the two.
The cold sink is the ambient air, and the "volume" of heat that can be removed is related to the surface area of the radiator, and the delta T between the radiator metal and the ambient air.
Lower coolant temperatures mean less heat transfer to the ambient...just like less temperature rise in the engine does.
These products claim to reduce nucleate boiling, which as a surfactant, then certainly can do. However nucleate boiling removes massively more (like multiple times the) heat from a particularly hot spot than simpl flow of coolant could ever do.
So in matching their claim of
a) reducing nucleate boiling; and
b) reducing coolant temperatures.
They are actually reducing the amount of heat removed from the engine, and in all likelihood making the hot parts that NEED nucleate boiling even hotter.
