Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
121 registered members (2013ecof150, AndyB, 2009Edge, AdRock, 55hambone, 2002 Maxima SE, 14 invisible), 1,811 guests, and 34 spiders.
Topics290,959
Posts4,853,329
Members66,063
Most Online3,590
Jan 24th, 2017
Page 1 of 5 1 2 5
hole in FRAM Ultra Synthetic leaked my oil out : #4319914
02/03/17 11:24 AM
02/03/17 11:24 AM
Dallas, TX
ZCJON888 Offline OP
ZCJON888  Offline OP
Dallas, TX
i have a 2003 honda accord LX V6 with 160,000 miles, i went to check my oil and was shocked to see that the dipstick was almost completely dry !!?, maybe just had a little bit of oil at the very tip end of it, but thats it, so i drove it slowly and carefully to a real close autozone and bought 2 quarts of oil, poured it in and drove over to a carwash nearby, and parked in the carwash stall, and turned the car off, and waited it to settle so i could check the oil level on the dipstick to see if it came up or not, and when i checked it, the dipstick still barely had anything on it!, even after just putting 2 quarts in it?, then i looked underneath the car real good with a bright light, and i saw a little stream of oil running down the pavement, then i looked to see where the drip was leading to, and there was no leak around the drainplug area, but then i saw that it was coming from the side of the oil filter, out of a small hole in it, and i don't have any idea how it happened ?, and i have never had that happen before either ?, but this one i got was a cheaper FRAM Ultra Synthetic (XG7317), but previously i always got Mobil 1 filters, but i thought that an oil filter is an oil filter, and they probably just do the same thing and thought it was fine just getting the cheaper FRAM instead, but i guess i was wrong ?
does anyone know of what types of things could cause that to happen to an oil filter ???, i just thought i would get opinions on this forum, since it has more knowledgable people that know about oil/oil filters and that type of stuff, and just so you know, when i tightened the filter when installing it, i first tightened it by hand til i could'nt turn it anymore, and then i gave it maybe one gentle turn using my oil filter wrench, (the squeeze type one, where its like pliers with 2 handles that you squeeze together and it clamps around the filter), but a guy on a different forum, where i made a post, said he thinks i still overtightened it ?, and he said really you don't even supposed to use an oil filter wrench at all, and also that you only supposed to hand turn it 3/4 to 1 turn after the gasket first makes contact, or something like that?, which does'nt seem like much ?, but maybe oil filters are just real fragile ?, or more than i thought ?
and by the way, all those scape marks around the filter and some of the dents, were most likely cause when i was yanking it around left to right, when i was removing it with the filter wrench, and i would'nt do it that hard if i were installing it, only when i know its old or bad like this one was, and that it did'nt matter if it was ruined while removing it or not, since i knew would'nt be using it again.
here is some pics of it, so you can see :
luckily i have another older 90 honda to use, and drove and got a new mobil 1 oil filter and new oil, (castrol edge syntec 5 X 30), and i put the filter and the oil in and ran it til the dipstick had the correct level on it, and drove car and no damage was done luckily, and checked to make sure no leaks were underneath and its all good, but i just wonder what caused the oil filter to form that crack or hole, that was leaking most of my oil out ???, and really i think it was probably some type of debris from the roadways ?, but i have read some things around the internet saying sometimes things like "oil pressure spikes" can cause an oil filter to rupture or make a puncture hole ?, so hopefully nothing internally from my engine did anything weird to cause it ?
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319918
02/03/17 11:27 AM
02/03/17 11:27 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
That oil filter had damage caused by a tool of some sort. How in blazes did that filter get all of those gauges and scratches?
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319919
02/03/17 11:27 AM
02/03/17 11:27 AM
NJ
Leo99 Online content
Leo99  Online Content
NJ
It's really chewed up. Was it that difficult to remove it that you had to bite into the filter with your pliers? Maybe it hit a rock or something. Hard to tell now if it was damaged while on the car or if you damaged it removing it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319920
02/03/17 11:28 AM
02/03/17 11:28 AM
WNY
redhat Offline
redhat  Offline
WNY
Lol is this a troll post?
That filter looks like it has been thrown against a concrete wall.
Who installed that filter? The whole grip texture is worn off. Better question, what was used to install it?
17 Taurus Limited AWD - MCSB 5W-20 FL500S, 10k
14 Civic EX Coupe - NAPA Syn 0W-20 WIX 57356, 63k
09 Accord Sedan 5MT - Traveler 15W-40 XG7317, 151k
87 Regal Limited - Carb 5.3 LM7 20W-50 VR1 WIX 51042
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319921
02/03/17 11:30 AM
02/03/17 11:30 AM
SW Louisiana
EricG Offline
EricG  Offline
SW Louisiana
That's mechanical damage caused by either, improper installation or debris on the road! You should have to use you "Plier Type" filter wrench to tighten the filter. I know my channel lock filter wrench has semi sharp teeth on it.
11 F150 4x4 5.0
11 Cadillac SRX
03 Century
95 K1500
94 Tercel
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319924
02/03/17 11:31 AM
02/03/17 11:31 AM
WNY
redhat Offline
redhat  Offline
WNY
Also IIRC, the Fram Ultra has one of the thicker canisters when compared to other filters.
I am surprised you punctured it with a filter wrench.
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319925
02/03/17 11:31 AM
02/03/17 11:31 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Looks like the filter was damaged, not a defect.
God Bless Our Troops
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319933
02/03/17 11:34 AM
02/03/17 11:34 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
who doesnt hand tighten filters? they only need to go 3/4 turn after gasket contact.
looks like you destroyed the filter removing it and decided to troll.
not saying you are.. just saying what it looks like.
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319934
02/03/17 11:35 AM
02/03/17 11:35 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
The filter hangs down by the half-shaft. Check the 3 minute mark on the video.
Road debris could very well have caused the hole.
https://www.youtube.com/watch?v=BHp0GRHMt38
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319936
02/03/17 11:37 AM
02/03/17 11:37 AM
WNY
redhat Offline
redhat  Offline
WNY
Any filter I put on is hand tightened, and removed by hand.
Jeez, my old filters are always in good enough shape that they could be put onto a beater with no worries.
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319940
02/03/17 11:38 AM
02/03/17 11:38 AM
Indiana
2civics Offline
2civics  Offline
Indiana
Does seem like an elaborate troll job. Maybe not...
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: redhat] #4319944
02/03/17 11:40 AM
02/03/17 11:40 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What do you think? The lack of capital letters, the run-on sentences, the general rambling over some weird problem. That is someone's hallmark writing style.
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319950
02/03/17 11:45 AM
02/03/17 11:45 AM
NC
Vladiator Offline
Vladiator  Offline
NC
The guy on the forum is right. You have damaged the filter casing during installation with the filter wrench. Maybe barely, but just enough to make the filter burst during the first oil pressure spike. YOU SHOULD NEVER USE A FILTER WRENCH ON A CANISTER TYPE OIL FILTER DURING INSTALLATION! The rule is - get it hand tight. Not tool tight - HAND TIGHT. It is more than enough to hold the filter in place during the pressure spikes or any other abnormal incidents. And will make it a breeze to take off during the next oil change. I do 1 full turn after gasket touches the block. Service over 20 cars in the family and friends zone, and never a single oil filter issue/failure. Hand tight my friend, hand tight.
2000 Lexus GS300-361k
1999 Lexus GS400-213k
2006 Toyota Camry-187k
2006 Toyota Highlander Hybrid-125k
2009 Scion xB-120k
2013 VW Tiguan-120k
2009 Toyota Tacoma-60k
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319952
02/03/17 11:47 AM
02/03/17 11:47 AM
Gone Fishing
John_Conrad Offline
John_Conrad  Offline
Gone Fishing
that was damaged by installation, the same can occur when removing a filter that has been tightened too much upon installation.
if trolling, i'm IBTL, if not the above is the cause.
i do not believe a rock would cause that, it very much appears to be pinch damage from over torquing to remove or install.
on edit:
i have seen this type damage before. i have not seen the hole type damage itself, but all the scuff and folding weakens the case.
Safety doesn't happen by accident.--author unknown
Re: hole in FRAM Ultra Synthetic leaked my oil out : [Re: ZCJON888] #4319953
02/03/17 11:47 AM
02/03/17 11:47 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Dude knows that already.
Remember, these pictures are after the filter was removed.
1994 BMW 530i, 228K
Page 1 of 5 1 2 5
