Credit Karma
by aquariuscsm - 10/22/19 01:20 PM
Does Fuel Dilution Leave Oil After Cause Resolved?
by LoneRanger - 10/22/19 01:11 PM
How do you select tires?
by ZZman - 10/22/19 12:12 PM
Shell TF-0870
by rooflessVW - 10/22/19 12:07 PM
Reverse tire look up?
by tiredguy - 10/22/19 11:35 AM
Oil consuming 2004 Mercury Marauder
by 2013ecof150 - 10/22/19 11:09 AM
2015 Triumph Trophy SE - Castrol 10W40
by Rick505 - 10/22/19 11:08 AM
need a mini van/suv for my son 10k
by BeerCan - 10/22/19 10:52 AM
Propene, polymer with ethene use in motor oil
by DrDanger - 10/22/19 10:29 AM
Wax recommendations
by dawgn86 - 10/22/19 09:46 AM
Oil and Filter Advice
by dawgn86 - 10/22/19 09:44 AM
Lift Master Remote RE-Programming
by Gebo - 10/22/19 09:10 AM
My '88 Daytona
by IronMaidenRules - 10/22/19 09:08 AM
QSUD and cleaning?
by irv - 10/22/19 08:56 AM
New 2019 Toyota Highlander first oil change
by thooks - 10/22/19 07:50 AM
2019 Golf R
by wings&wheels - 10/22/19 06:47 AM
My latest battery load test
by Char Baby - 10/22/19 05:18 AM
MB Loctite 5970
by The Critic - 10/22/19 01:18 AM
Amazon Special on Lubegard LXE
by Marco620 - 10/21/19 11:42 PM
TV_Viewer2, Finner, blimo, Haiducek, NoRegrets
69642 Registered Users
107 registered members (2013ecof150, 28oz, 14Accent, 53' Stude, 2010Civic, 6 invisible), 2,234 guests, and 28 spiders.
Topics296,329
Posts5,095,725
Members69,642
Most Online3,532
Jul 30th, 2019
Transmission Service on 2000 F150? #4318641 02/01/17 05:46 PM
L
lawnguy Offline OP
L
Does it really matter if I just get a trans, flush with the machine using kendall fully synthetic,or having it done by dropping the pan,etc ? My truck has 115l miles on it,and I bought it used not knowing the previous history. I do know that that it bought bought brand new and used by a county municipality.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318648 02/01/17 06:08 PM
F
Farmer Offline
F
I would try to get the filter changed. Then fill with something cheap. Then change all the fluid out with your preferred fluid.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318650 02/01/17 06:12 PM
demarpaint Offline
I'd do both, assuming the machine is doing a fluid exchange. I'd want the filter out and the pan and magnet cleaned up.
God Bless Our Troops
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318652 02/01/17 06:16 PM
Donald Offline
The filter needs to be changed if it's never been changed before.
Don't let them bull pooh you saying the flush machine will clean the filter. It will not.
2015 Ford F250 w/Powerstroke
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318658 02/01/17 06:21 PM
K
Kuato Offline
K
I would avoid the flush and do a pan drop and refill with filter.
Too many stories of transmissions with over 50k miles having problems after a flush.
Thick vs Thin test: 15k / 43k miles complete
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318668 02/01/17 06:41 PM
cb_13 Offline
Check for a torque converter drain. I believe it was until 2001 that F150's had them. That's makes a flush unnecessary.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318669 02/01/17 06:43 PM
I
i_hate_autofraud Offline
I
Yup, get rid of the old filter, they're designed smaller to clog up way early to make money off customers, gone are the days you can run on the same filter and fluid for 20 yrs!
Re: Transmission Service on 2000 F150? [Re: i_hate_autofraud] #4318672 02/01/17 06:49 PM
cb_13 Offline
You mean gone are the days of a metal screen. Most apllications use actual filters now and therefore can clog up.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318758 02/01/17 08:51 PM
slacktide_bitog Offline
If your transmission doesn't have a drain plug, see if Dorman makes a transmission pan for your truck. Dorman pans include a drain plug for easy ATF changes smile
Maxlife is awesome ATF, unbeatable for a full synthetic ATF in terms of price and availability.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318777 02/01/17 09:23 PM
M
merconvvv Offline
M
+1 on the dorman pan with drain plug. But stick with mercon v if thats what it calls for. Mercon v is like 30 bucks for 5 quart at amazon and similarly 6 bucks a quart at ford dealer.
I had dorman installed at about 160k miles on 1999 expedition. That was its first ever atf changed since i got it new. I have drained it 4 or 5 times since then myself. Its even easier than oil/filter change. I had quick lube pennzoil install the pan and new filter/clean magnet as part of their "drop the pan" service. About 60 dollars n i supplied the atf. I never messed with draining the torque converter. I ordered dorman plus filter plus 5 quart fluid from amazon and got free shipping if i recall correctly. Dorman pan was less than 30 i think. I got a magnetic drain plug for it smile
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318778 02/01/17 09:31 PM
69GTX Offline
Your F150 was originally specced for Mercon. And in 2006/2007 Ford upgraded Mercon to Mercon V. Maxlife may be awesome, but it doesn't meet the Mercon V specs.
Ford ATF specs
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318784 02/01/17 09:49 PM
69GTX Offline
Walmart SuperTech Mercon V is Ford approved and under $5/qt. If you go to a Quick Lube place they might stick Merc/Dex III into those vehicles requiring Mercon V. Been there...done that.
1969 Ply GTX/RRs
Re: Transmission Service on 2000 F150? [Re: 69GTX] #4318785 02/01/17 09:51 PM
cb_13 Offline
Ford ATF specs
A 2000 with 4R70 would have been originally spec' for Mercon V. Not sure exactly when the spec changed but my 98 had Mercon V on the dipstick and called for it in the owners manual.
Re: Transmission Service on 2000 F150? [Re: 69GTX] #4318788 02/01/17 09:52 PM
cb_13 Offline
+1 I've used supertech Mercon V in my Fords in the past with great results.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318792 02/01/17 09:58 PM
M
merconvvv Offline
M
Motorcraft mercon v is 6 bucks a quart.
