Is my transmission fluid overfilled? Scion xB '10
by puredata - 08/22/19 02:38 AM
Which are you?😂
by Mad_Hatter - 08/22/19 12:21 AM
The Fatal Flaw...
by Mad_Hatter - 08/21/19 10:58 PM
early OCI because of HIGH REVVING
by tahoe_hybrid - 08/21/19 10:38 PM
API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
oilq, Nesss, Robto, Chaparro_trucker, KiwiBiker
69027 Registered Users
23 registered members (bonjo, 4WD, 2015Corolla, ChrisD46, Bailes1992, DR3406C, 3 invisible), 565 guests, and 26 spiders.
Topics293,636
Posts5,043,857
Members69,027
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Transmission Service on 2000 F150? [Re: slacktide_bitog] #4318801 02/01/17 10:08 PM
9
901Memphis Offline
9
Originally Posted By: slacktide_bitog
If your transmission doesn't have a drain plug, see if Dorman makes a transmission pan for your truck. Dorman pans include a drain plug for easy ATF changes smile
Maxlife is awesome ATF, unbeatable for a full synthetic ATF in terms of price and availability.
The Dorman pans seem like a good idea but when I used it with the oem gm gasket on my 4T65e it leaked some. I went back to the oem pan
2012 Chevy Cruze LT 1.4T - 62k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 147k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Transmission Service on 2000 F150? [Re: i_hate_autofraud] #4318816 02/01/17 10:33 PM
clinebarger Offline
Originally Posted By: i_hate_autofraud
Yup, get rid of the old filter, they're designed smaller to clog up way early to make money off customers, gone are the days you can run on the same filter and fluid for 20 yrs!
Are you high, Or do you just randomly make $hit up??
2001 Chevy Camaro L92/4L80E
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4318821 02/01/17 10:40 PM
blupupher Offline
Do a pan drop and change the filter. Don't do a flush (especially a power flush that uses chemicals). You could do a "flush" using the cooler line letting the trucks pump do the work (several how to's online), but still do a pan drop.
As said, a 2000 may have a torque converter drain plug, makes it easy to get most all the fluid out at once without "flushing" it.
I installed a drain plug in mine, wish I had gone with the Dorman pan, only like $25 on amazon, and no chance of it leaking like installing a drain plug yourself. Mine does not have a torque converter plug, so I have done several drain and fills after I did the initial filter change. AS said above, with a drain plug, it is a quick thing to do a drain and fill (I will do it every 10,000 miles, it gets 4 qts out of ~14 qts in the system). I keep debating installing an inline filter.
You don't mention if you have the 4R70W or 4R100. Both can use Mercon V though (4R100 originally spec'ed for Mercon, but there is no licensed Mercon fluid anymore, and it has been back spec'ed for it).
Amazon has Havoline Mercon V for around $45 sometimes for 12 qts, as well as Supertech Mercon V for $4.27/qt at Walmart. First change I used the Supertech Mercon V, the last 3 I have used Maxlife. I have also used Maxlife in my BIL F150.
Some have issue with Maxlife being too thin (5.9 cSt @ 100C) compared to Mercon V (7.5 cSt @ 100C), but seems I had read that Mercon V shears quickly to lower than what Maxlife is, and Maxlife is more sheer stable.
2018 Santa Fe: PP 10W-30/OEM/5k
2018 Soul: Mobil Super 5W-20/OEM/5k
2012 xB: M1 EP 0W-20/CQ Blue/5k
2002 F150: Magnatec 5W-20/Bosch D+/1yr
1994 VT1100: Peak 15W-40/Bosch D+/1yr
Re: Transmission Service on 2000 F150? [Re: cb_13] #4318823 02/01/17 10:42 PM
69GTX Offline
Originally Posted By: cb_13
Originally Posted By: 69GTX
Your F150 was originally specced for Mercon. And in 2006/2007 Ford upgraded Mercon to Mercon V. Maxlife may be awesome, but it doesn't meet the Mercon V specs.
Ford ATF specs
A 2000 with 4R70 would have been originally spec' for Mercon V. Not sure exactly when the spec changed but my 98 had Mercon V on the dipstick and called for it in the owners manual.
Interesting. In any case, it takes Mercon V today.
4R100 and manual 5 speed F150's in 2000 take the Mercon
The Ford AX4N went through a similar Mercon to Mercon V change between 1997 and 2002. As my 1997 and 2002 were specced for different fluids.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4319827 02/03/17 09:31 AM
M
merconvvv Offline
M
Original post what was the charge for flush on f150?
Incidentally, on my expedition that has never towed, the large factory magnet inside the pan had about 5 ounces of metal shavings attached to it (little more than half filled 8 0z cup with roughly 160k miles).
The dorman pan also has a slot for this strong magnet.
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4320247 02/03/17 05:07 PM
E
emmett442 Offline
E
For anyone on the fence about the Dorman trans pan, I installed on one my 4r75e (same pan as your 4r70). It is nearly identical in every way compared to the original. Same shape, thickness, provision for the magnet, same gasket flange. A perfect fit. No leaks reusing the factory gasket.
As a skeptic of most Dorman products (I've gotten some Dorman junk in the past), this trans pan was a pleasant surprise. For anyone hemming and hawing due to the Dorman label, don't worry in this case. It's a fine replacement.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4320445 02/03/17 09:26 PM
M
MRtv Offline
M
I put a Doorman on my 97 F150. No regrets. No leaks. I do a fluid drain and replace every other oil change now to freshen up the fluid. I use the Supertech Mercon V.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
Re: Transmission Service on 2000 F150? [Re: cb_13] #4320451 02/03/17 09:35 PM
I
i_hate_autofraud Offline
I
You mean gone are the days of a metal screen. Most apllications use actual filters now and therefore can clog up.
I guess you forgot the "LOL"
I do know 60's - 80's Chrysler A727 and A904 trannies all had actual filters, mostly to catch the clutch plate wear materials. I never "had" to change them either, I'm sure OEMs noticed and made smaller filters to force customers to the garage!
Re: Transmission Service on 2000 F150? [Re: emmett442] #4320948 02/04/17 02:28 PM
F
ford46guy Offline
F
The dorman pans could just as well have Ford stamped on them, they are really nice. And cheap too! I have 3 installed, factory ones had flange rust and leaks, and for $20 bucks I'm not messing with it (I also have the awesome drain plug, no more mercon showers). Wish all their products were that good. Old pans make good tool bins when I work on things.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Transmission Service on 2000 F150? [Re: i_hate_autofraud] #4323768 02/07/17 10:16 PM
cb_13 Offline
And I guess you forgot your tinfoil hat! The planned obsolescence theory is way outdated.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4323923 02/08/17 07:42 AM
B
Black_Thunder Offline
B
I've used supertech, valvoline, castrol and house brand Mercon V, never a problem with either.
i would avoid the flush as well, just do a pan drop and maybe drain the torque converter, will probably be around 13 quarts to fill it all back up again.
and yes depending on the transmission it may only be mercon not mercon V
i know the 4R70w from 98 and on spec'ed Mercon V but my 98 f250 and my dad's 2000 f250 with the 4R100 take regular mercon.
It will say on the dipstick/owners manual what fluid it should take.
I'd buy Callahan autoparts if I could.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #4324121 02/08/17 11:48 AM
N
nthach Offline
N
I'd stick with Mercon V - no need to go fancy here although MaxLife is cheaper. Drop the pan, change the filter with OEM or the US-made Allomatic and if you have a torque converter plug, it's not a bad idea to drain that as well.
Re: Transmission Service on 2000 F150? [Re: lawnguy] #5131963 06/12/19 03:31 AM
DoubleNickels Offline
[Linked Image]
Re: Transmission Service on 2000 F150? [Re: lawnguy] #5131997 06/12/19 05:35 AM
L
Lubener Offline
L
Originally Posted by lawnguy
Does it really matter if I just get a trans, flush with the machine using kendall fully synthetic,or having it done by dropping the pan,etc ? My truck has 115l miles on it,and I bought it used not knowing the previous history. I do know that that it bought bought brand new and used by a county municipality.
Old post but there might have a converter drain plug. In that case, drop the pan, change the filter, throw out the shipping plug and change it all.
The "thinking" man's friend.
Page 2 of 2 1 2
