Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
129 registered members (92saturnsl2, 4WD, 77GrandPrix, 01rangerxl, 1foxracing, 2015_PSD, 9 invisible), 2,000 guests, and 53 spiders.
Topics286,086
Posts4,902,290
Members67,560
Most Online2,967
Mar 10th, 2019
Frantz Fuel Filter install #4314491
01/28/17 12:57 AM
01/28/17 12:57 AM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
I've been pondering different fuel filters for my 2009 6.4 Powerstroke for quite some time now and decided to install one of my Frantz units. I bought an in-bed DeeZee 50 gallon tank with a gravity feed line to my Frantz, then to the filler neck hose. I drilled out the orifices in the Frantz and plumbed it all in. Filled the tanks and checked for leaks and all is good. Will test it out tomorrow and the next day on a 10 hour return trip. Here's some pictures:
Scrap steel backing plate:
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: Frantz Fuel Filter install [Re: A310] #4316226
01/29/17 09:21 PM
01/29/17 09:21 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Got back from my road trip and it worked really well but as you can imagine gravity alone can't push the fuel through the filter fast enough to keep up with engine consumption. Turns out to feed around half what the engine needs, so I'll be installing a transfer pump along with an electric shut-off valve to make the system full proof. More details to come:)
Re: Frantz Fuel Filter install [Re: A310] #4317967
01/31/17 08:25 PM
01/31/17 08:25 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Very nice work A310 smile. Keep us posted kind sir
Re: Frantz Fuel Filter install [Re: 53' Stude] #4318408
02/01/17 12:53 PM
02/01/17 12:53 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Sure will, working great so far around town just with gravity feed. Once it warms up again I'll install the transfer pump and shut off valve.
Re: Frantz Fuel Filter install [Re: A310] #4319705
02/03/17 12:55 AM
02/03/17 12:55 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Heating the filter might help too. Diesel gets fairly thick at low temps. Like a Zerostart 3400039. Its 12v 50W. Run it when the key is on. Keep the filter warm and it might be able to keep up.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Frantz Fuel Filter install [Re: A310] #4426147
06/08/17 06:12 PM
06/08/17 06:12 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
I did some maintenance on my truck and decided to have a look at my Frantz fuel filter. I've put 6000 miles on it since the install and am very pleased indeed. I'm still gravity feeding the filter, but will be installing my transfer pump in the next month or so. All fuel is added to the aux tank and filtered through the Frantz to my main tank. Most of the debree in the fuel is probably caused by me having to heat the tank bung to get it out, burned a lot of the paint inside the tank near the bung. Here's some pictures and a video:
http://www.youtube.com/watch?v=lLdxNJJ1jM4
Re: Frantz Fuel Filter install [Re: A310] #4428094
06/10/17 08:18 PM
06/10/17 08:18 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Well I finally got some time to finish this install with a Carter transfer pump and an electric shut-off valve. I connected the pump and shut-off valve in series and run off my upfitter switch in the cab. I did have to take the filter and mount off the truck to re-jig it to fit the additional pump and valve. Works really well, so very pleased indeed. Here's some pictures of the install.
Re: Frantz Fuel Filter install [Re: A310] #4432385
06/15/17 02:11 PM
06/15/17 02:11 PM
ohio
xtell Offline
xtell  Offline
ohio
Nice, clean set up. Prior to installing the Frantz, how often were you changing out the factory filter?
Re: Frantz Fuel Filter install [Re: xtell] #4435393
06/18/17 06:46 PM
06/18/17 06:46 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Thanks, I changed them every 20000 miles. I could have gone longer as they were very clean, but I did not want to take a chance on them. Now that I have this system installed I'll change them every 30000 to start and see how they look.
Re: Frantz Fuel Filter install [Re: A310] #4435416
06/18/17 07:04 PM
06/18/17 07:04 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
P.S. Takes 1 hour 20 minutes to pump 20 gallons through the Frantz.:), that's just over 1 quart a minute adjusted for fuel consumption.
Re: Frantz Fuel Filter install [Re: A310] #4455744
07/10/17 09:52 PM
07/10/17 09:52 PM
State
Rockrz Offline
Rockrz  Offline
State
What happened to the pics?
They no be showin anymore...
Re: Frantz Fuel Filter install [Re: Rockrz] #4463159
07/18/17 06:21 PM
07/18/17 06:21 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Photobuckets decided to hijack everyone with a $400 dollar fee to allow 3rd party photo viewing. I'm not going to pay for that, so all my photo's are now gone. I'll most likely go with google drive or something similar from now on. Not sure what Photobuckets was thinking?
