VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
30 registered members (4WD, A1O, antik, billt460, bfleeman, ctechbob, 4 invisible), 497 guests, and 57 spiders.
Topics286,267
Posts4,905,521
Members67,589
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Need quality clutch master and/or slave cylinder #4312781
01/26/17 12:37 AM
01/26/17 12:37 AM
By Detroit
TallPaul Offline OP
TallPaul  Offline OP
By Detroit
I have a 2001 Ford Ranger with a manual transmission. The original slave cylinder went out at 70,000 miles and was replaced only to be eaten by a blown release bearing 10,000 miles later. At that time the slave, release bearing, and clutch were replaced. Then we discovered that the master cylinder was leaking and that also was replaced, all about at 80,000 miles. Around 100,000 miles the master cylinder was leaking again and had to be replaced.
Now at 119,000 miles I have a new clutch hydraulics leak. I am not sure if it is the slave or the master but it will get hard to put into first gear, so I will pump the pedal about 40 times and it is good for a day. Then I have to do it again. So, I am taking it in and hoping it is the master as that is a lot cheaper to replace.
The question is, what brand master or slave is going to go the long haul? I don't want to have to replace clutch hydraulic components every two years. I want something to last the remaining life of the truck.
My 1984 F100 had hydraulic clutch linkage and I never had any trouble with it. The hydraulics lasted over 200,000 miles without even a fluid change. Is this what the world has come to? Everything is junk? Surely the Mustang drivers won't put up with cheap clutch hydraulics. There must be good parts out there. Is the answer to get genuine Motorcraft parts? I don't know what brand parts were put in before but I bet they were not Motorcraft.
Obnoxious seems to be the styling cue for modern automotive design.
Re: Need quality clutch master and/or slave cylinder [Re: TallPaul] #4312784
01/26/17 12:43 AM
01/26/17 12:43 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Go with the genuine Ford parts. They are not Motorcraft, but blue label Ford Genuine.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Need quality clutch master and/or slave cylinder [Re: TallPaul] #4312849
01/26/17 07:00 AM
01/26/17 07:00 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
My 1993 Ranger has a 5.0 swap, with a "King Cobra" pressure plate, and a 280ZX slave cylinder.
The original clutch master started acting up around 120,000 miles or so, and by luck I found one on ebay (Genuine Ford) and swapped it in (around 2006 or 07?)... It's still holding up well. I'm pretty sure I did a new slave at the time because I wasn't sure which component to blame.
Re: Need quality clutch master and/or slave cylinder [Re: TallPaul] #4312850
01/26/17 07:01 AM
01/26/17 07:01 AM
USA
mk378 Offline
mk378  Offline
USA
Having to pump up but not losing fluid means that the master has an internal problem.
Re: Need quality clutch master and/or slave cylinder [Re: bdcardinal] #4312864
01/26/17 07:25 AM
01/26/17 07:25 AM
NY
demarpaint Offline
demarpaint  Offline
NY
+1 Don't even think about something from the aftermarket for it.
God Bless Our Troops
Re: Need quality clutch master and/or slave cylinder [Re: mk378] #4312870
01/26/17 07:32 AM
01/26/17 07:32 AM
By Detroit
TallPaul Offline OP
TallPaul  Offline OP
By Detroit
Yeah, last time it was leaking out under the dash where the shaft goes in.
Re: Need quality clutch master and/or slave cylinder [Re: bdcardinal] #4312871
01/26/17 07:33 AM
01/26/17 07:33 AM
By Detroit
TallPaul Offline OP
TallPaul  Offline OP
By Detroit
Please educate me. I have never heard of the "blue label" Ford Genuine. Would this be from the dealership, Or do they sometimes pawn off Motorcraft parts on unwary people?
As a side note on parts quality, about 12 years ago I had an Aerostar and the fuel pump went out. Shop put in two Carter fuel pumps (supposedly a quality brand). Both were bad. Then they got a Motorcraft pump which worked for years with no problems.
Re: Need quality clutch master and/or slave cylinder [Re: bdcardinal] #4312876
01/26/17 07:37 AM
01/26/17 07:37 AM
Kansas
Kruse Offline
Kruse  Offline
Kansas
The truest post you will see on the subject. Ford replacement parts will cause the customer to complain one time...when the bill is paid. Aftermarket parts will cause the customer to complain a few months or a year later, when there is a problem with the parts, especially the slave cylinder parts.
If you are completely allergic to genuine Ford replacement parts, roll the dice and install a Luk clutch, although I can't comment on the quality if you do any towing.
Re: Need quality clutch master and/or slave cylinder [Re: TallPaul] #4312934
01/26/17 08:59 AM
01/26/17 08:59 AM
Waterloo, ON
Bluestream Offline
Bluestream  Offline
Waterloo, ON
Make sure your hydraulic line has been bled properly... those lines have a dip in them that makes it hard to bleed by pumping the pedal. a pressure bleeder is needed
2000 VW Beetle 1.8T M5
2006 Pathfinder 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
Re: Need quality clutch master and/or slave cylinder [Re: mk378] #4313010
01/26/17 10:31 AM
01/26/17 10:31 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
While I would normally agree I had a 2005 ranger that did the same thing and it was the slave cylinder. Which is a well known issue they go out around 100k miles or so.
now that this is all muddied up with aftermarket parts.. who knows.
Re: Need quality clutch master and/or slave cylinder [Re: Bluestream] #4313640
01/26/17 11:01 PM
01/26/17 11:01 PM
By Detroit
TallPaul Offline OP
TallPaul  Offline OP
By Detroit
Well it had been working fine for about 1.5 years so I am thinking must be a leak. Unless some air was in it and managed to eventually move to a different location where it affects things and by pumping I am getting the air to move out but not all the way out, so it comes back. I suppose that is possible and would be better than a leak. But I am not going to try bleeding it on my own. I'll have to take it in. Problem is most shops don't know how to do it. Last time I had the master replaced it took the shop over a week to get it bled. They weren't working on it constantly but off and on when they had spare time because I was not charged a lot of labor. But I had no truck for a week. I don't need that either. It has to be in and out in one day. Maybe the dealership is the way to go.
Re: Need quality clutch master and/or slave cylinder [Re: TallPaul] #4313657
01/26/17 11:16 PM
01/26/17 11:16 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Not every Ford part is Motorcraft. Parts sold under the Motorcraft name are available in places other than the dealer. Parts with blue stripes on the label are captive at dealers and not made available to other store officially. The difference in packaging is obvious. Motorcraft parts have the red and black labels where the Ford genuine have blue labels. There are cases where there are both a Ford and a Motorcraft part, such as with brake components. The value line will have a V in the base (middle section) of the part number where that will not be present on the Ford part. An example is Ford brake pads will have a 2001 or 2200 base number where Motorcraft value have 2V001 and 2V200. Similar idea to the ACDelco OE vs Professional parts lines.
Re: Need quality clutch master and/or slave cylinder [Re: bdcardinal] #4314158
01/27/17 04:11 PM
01/27/17 04:11 PM
Long Beach CA
lbhsbz Offline
lbhsbz  Offline
Long Beach CA
I work for a company at manufactures/distributes brake and clutch hydraulics to the aftermarket.
The OE manufacturer on your hydraulics is FTE. Ford has had several different versions of this part over the years, and they all mostly suck.
I spent some time on the phone with an engineer at FTE about 10 years ago discussing this particular system...there is no good way to do it. You can't have a dust boot that seals properly because it will end up wadding up, so you have vent the dust boot, which obviously allows dust in. Effectively, you have exposed hydraulic sealing surface in a hot container of flying abrasive dust. That won't end well...and mostly doesn't. We supply the FTE parts for this application and many others, and the failure rate is higher than normal. FTE / Ford is the most reliable one of these you'll find.
If you don't see any leaks, you have a bleeding problem...which is much more common since the master cylinder points down at an angle....air cannot escape from under the piston seal. If replacing individual components, one has to either jack the front of the truck up until the master cylinder bore is level before bleeding, or bleed the whole assembly on the bench with the master cylinder level, then undo the dry break connector, assemble everything in the truck, and reconnect. The other option is to replace with a pre-bled slave cylinder (all the OE /FTE ones come pre-bled) and a pre-bled master cylinder/line assembly.
Re: Need quality clutch master and/or slave cylinder [Re: TallPaul] #4315159
01/28/17 07:41 PM
01/28/17 07:41 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I bought a 94 Ranger with a worn out clutch. Going in I figured I'd replace the disk and motor on. I have changed many VW bug clutches. Easy afternoon job. If my BMW were a manual shift, I could replace all the clutch hydraulics without dropping the trans. The Ranger wasn't designed to be taken apart. Plus it had been run on the beach and rusted just about solid in places. I replaced everything inside the bell housing. I also knew about the bleeding deal. The way I did it was to connect all the parts together with the MC loose from the firewall. This procedure was explained in 3 languages on the instruction sheet for the MC, the hose and the slave BTW. That way it can be gravity bled. The push to connect allows you to bleed all the way to slave coupling before attaching the hose to the slave. then you top off the reservoir and open the bleeder on the slave. Once you have a steady drip, tighten the bleeder, you're done. Almost. Now bolt the MC to the firewall. All the parts I used came from Auto Zone or Parts Geek. I used a LUK rep set but MC and hose were from AZ. The clutch action is as smooth as butter and I can idle around in first by feathering the clutch. Its been 5 yrs and maybe 5k miles
Thick oil is better grin2
Re: Need quality clutch master and/or slave cylinder [Re: TallPaul] #4317205
01/30/17 10:04 PM
01/30/17 10:04 PM
By Detroit
TallPaul Offline OP
TallPaul  Offline OP
By Detroit
Maybe I should get an AC Delco master cylinder. My son has an S10, same year as my Ranger, about the same miles and it is on the original master and slave and still working great. Of course that was 2001 parts and now it is 2017.
Sounds like it is best to get the pre bled with reservoir and line to tranny attached. Do you have any issues with air getting in when it is connected at the slave? How difficult is it to install the master? Kind of hard to work way up under the dash.
Page 1 of 3 1 2 3
