Originally Posted By: roadrunner1
I would be very curious to see oil temp differences between a 5w-40 & 10w-30 in extreme high temp conditions. My guess is that a 10w-30 should run cooler by at least 5f. In all that I've done with my 6.7 I haven't experienced anything above 215f oil temp, which is only 3f above where oil is rated (cST 100C). As I stated I don't have mountains here, but I have been loaded down in the bed(4,000 lbs.+) and towing a 12,000 gvw trailer loaded along with 4 guys in the cab in 90f+ summer temps and run 145 mi. back home down the highway at 65-70 mph to achieve the 215f as I generally see 201f-205f.
I do have a 3.31 rear end which puts me at roughly 1,550 rpm at 70 mph, but UOA data doesn't suggest that my lower rpm's are affecting engine wear in high weight/low rpm conditions using 10w-30.
Not sure; my "normal" temps are right where yours are, but as noted in other posts, I have also seen 240°F and I (just me speaking for me) would not use anything other than a synthetic and an xW-40 at those temps.
"Those Temps" as you put them are no where near a dangerous temp for any CJ-4/CK-4 oil.
I went back and looked at my post regarding the temperatures and I hit 249°F at the highest. I sent an inquiries to all of the majors (Chevron, Mobil, Phillips, and Shell) and Mobil, Phillips, and Shell (Chevron did not say much of anything as per usual with their responses) all recommended synthetics for those operating temperatures.
Mobil stated "those temps" are at the limit for conventional oils. Would the engine self destruct? Of course not, but the life of the oil can be exponentially reduced when operating at those temps. We went through all of this in June of 2016 and I am still confident with my choices. However, to each or her own...
