Originally Posted By: rooflessVW
No need to worry about the plastic bits for another several years, if ever.
Castro! 0W-40 would be my choice.
DSG and Haldex services every 40k. OEM fluids only. You won't have any issues with buildup (if you have any at all) until you're near 100k.
Enjoy the car. Where are the photos?
Whoops, forgot the pics! I just put a quick album together, sorry for the production quality
2017 Golf Sportwagen Album
Yea, its probably a totally unfounded fear of the plastic bits. I'm sure they wouldn't use it if they didn't have confidence in it. I've been looking into the DSG service, Doesn't honestly seem terrible at 40k miles. Looks like the kits with the tools and fluid and everything run about $250. Then changes after are cheaper as you only need the fluid and filter. Have you serviced any of the haldex systems? Is that just changing the fluid in the rear diff?
Yeah just the rear differential needs the special Haldex juice.
You can do the DSG service yourself. If you're in it for the long haul, I also recommend a Ross-Tech cable and Vag-Com Diagnostic Software.
Good looking car!
DSG requires DSG juice
The haldex coupling requires haldex juice
the rear differential requires 75w90 gear oil.
