2009 Nissan Navara D40 2.5L/AmsoilSS 5w30 10.340KM
Greece
hi guys first time on amsoil after all previous samples with Redline,
car is a Nissan Navara D40 2.5l Diesel with 106.500 km, oil is Amsoil Signature Series 5w30 with 10.340 km on it and Fram Ultra filter
i think its going way better than Redline, but im a bit worried about the viscosity but will i let you comment on this..
The oil has life left I agree with you about questioning the viscosity. The viscosity is here link to Amsoil. There are probably other oils that will serve you better.
Wrong oil to use. Not for diesels. Amsoil Signature Series 5w30 is for gasoline engines only.
That said, it did good on iron wear.
Light duty diesel it will work on. We use in EU acea c1 to c3 oil in diesels and amsoil will out perform them even if sinature series is for petrol. Been using this oil for my Hilux for a long time with no problems
