Valvoline Maxlife Tranmission fluid spec sheet has been updated as of 01/12/2017
http://content.valvoline.com/pdf/maxlife_atf.pdf
Biggest thing that stands out is in CA you can't say your fluid works if the viscometrics are different from the OE fluid. Seems to be only for the older Mercon fluids. What that means is the Maxlife is a lower viscosity when new compared to the older spec Mercon. But older Mercron, and even Dex3, would shear down pretty quick. Maxlife is a Syn fluid and does not have the shear issues so they can use a thinner fluid. But that is against the law in CA.
So maxlife will work fine, nothing to get alarmed about.
The other things I see are more Mopar, GM Autotrak II, and Miscellaneous OEM specs listed. I don't remember them all from before.
So seems it has been getting more test and the spec sheet is being updated.
