TY so much for this tidbit. I have spent a BUNCH on batteries whether ATV, UTV, little or BIG B/H/loader, pickups and the most critical, a bank of eight 6v Trojan RE16-B's for the home solar. We are off grid for 10 years - I know about maintenance: watering, SGs, EQ, etc., etc. trying to stretch the life. Not only the life but the performance because if I can improve performance then the genset autofires less when voltages drop to "charge time" and then I'm buying fuel.
So, could you add some detail to this this comment? Is it with regard to the desulfator/charger combo, the stand alone desulfator?
I recently bought two 12vdc OBD desulfators to try on the small stuff. I'm experimenting. If it has value then it will be better, else worse or blah by next spring. If the BatteryMinder desultator works to even a moderate degree then the improvement to battery performance could be killer good.
Then after this experiment will be the 48vdc bank. THat will be interesting if it is worth the try.
Best, JRHill
