Some AGM batteries, do not really have the low self discharge rate quality that all AGMS seem to have as attributes. The most popular AGM sold in Flaps and relabelled is the Deka intimidator. Its self discharge is not much better than a flooded, and neither are the CCA figures, but it is sealed and should not offgass and corrode battery terminals. Its claims to higher cycle-ability and lifespan are highly suspect, and in comparison to higher$$ AGMS does not stack up in cycles, CCA, or self discharge.
AGM has become a marketing term as much or more than an actual design term, as the general public knows they cost more, and attribute 'super battery' status to them.
The battery manufacturer listed float voltage, which should be temperature corrected, varies 0.6v among different AGM manufacturers. So super battery maintainer brand X, could easily miss the mark.
If I am using my DC power supply set at 13.2v in the intent of keeping my AGM battery fully charged while I power DC loads, if I goose the voltage to 14.4v, the amperage it accepts indicates that somehow the battery was being discharged while being kept at a voltage higher than its fully charged resting voltage.
The break even point on my AGM in mild temps is 13.6v, which happens to be the recommended float voltage by Northstar. If I hold it at 13.6v while powering DC loads and goose voltage to 14.7v, amps quickly taper back to near zero. If I hold it at 13.2v while powering DC loads and goose it to 14.7v, amps go as high as 1.1, and then slowly start tapering toward Zero and might take a half hour more more to taper back to near zero, indicating the battery was being 'trickled' but still slowly discharging.
This changes with battery temperature too. At 54f battery temperature I raise float voltage to 13.8v or the goosing to 14.7v reveals the battery was discharging.
Not sure why this is, only that it occurs and is repeatable, and All I have to do is twist a dial to compensate, but someone with a bells and whistles 23 stage charger with extra special marketing simply gets to put faith in the marketing material and stick their head in the sand.
Measuring tools and reality be Danged.
So a maintenance charger would Ideally have a battery temperature sensor And a user selectable float voltage for whatever brand of AGM they are trying to maintain at 100% full charge.
But this product would never sell well to the masses, as user selectable settings and 'fully automatic' are not one and the same in this day and age of automatic everything.
