It seems most booster cables out there use "copper-clad aluminum (CCA)" wiring.
https://en.wikipedia.org/wiki/Copper-clad_aluminium_wire
This makes them lighter, more flexible and cheaper than if the wiring was made of pure copper of the same gauge.
As for as resistivity, CCA with 10% copper has a resistivity of 2.74 Ohms cm 10-6
This is slightly better than aluminum's own resistivity of 2.65 Ohms cm 10-6
But this is nowhere close to copper's 1.68 Ohms cm 10-6
I can make 100% some 16 feet stranded copper jumper cables using 6 ga stranded copper wiring for the same price that I can buy pre-made 2 ga CCA jumper cables.
Am I better off with the copper ones using a smaller gauge wire?
