I was recently servicing a 2006 Ford Freestar and changed out the old factory plugs. I noticed one bank had plugs labelled "AGSF-34EM" and the other banks "AGSF-34EGM". Not sure what the difference between the EM and EGM is, or why different banks have these two different plugs from factory. A quick search seems to indicate these fall under the Motorcraft SP504 part #. These are both platinum plugs.
Strangely, in any part # lookup for this vehicle, and other similar Ford vehicles using the Ford 4.2 engine, the recommended plug is a Motorcraft SP506 which is a copper plug.
Does anyone know why the discrepancy? Can I just use the platinum SP504 for future services? Mainly to double the service life because the rear bank of plugs is a PITA to change on minivans so reduced servicing would be nice. Or could I even look into an iridium plug for even longer life?
Thanks!
Thanks!
